R56 Composite Camshafts?
Old Apr 29, 2008 | 08:11 AM
VelvetFoot's Avatar
VelvetFoot
I read that the R56 models have composite camshafts.
What exactly does this mean?
Old Apr 29, 2008 | 08:15 AM
VelvetFoot's Avatar
VelvetFoot
Never mind. I found this:
The camshafts on both engines are composite structures, meaning that cam
rings made of high-strength stainless steel are shrunk on to a cast shaft and
subsequently machined. In the final fine-polishing process the cams are then
machined to an accuracy of 1 micron (1⁄1,000 mm). For reasons of weight
the eccentric shaft is also made in this process for the first time, likewise with tolerance levels in the micron range.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
gnhovis
Sep 28, 2015 04:07 AM
yukinoinu
11
Sep 25, 2015 09:48 AM
sirfrank
Sep 11, 2015 01:36 PM
Sep 11, 2015 11:09 AM
