R50/53 Idle probems
Old Apr 28, 2008 | 08:30 PM
dandennis123's Avatar
dandennis123
Idle probems
my car is idling really low like between 6 and 8 hundred?
i have
unichip
alta 17% sc pully
magnaflow muffla with a lil bit of piping
msd coil pack
and
dinan intake no silicone hose
and theirs no check engine light and one kno whats up with my car? its really pissing me off
Old Apr 28, 2008 | 08:33 PM
ScottRiqui's Avatar
ScottRiqui
Did it just start doing it all of a sudden, or did you recently make any changes to the car?
Also, do you only have the low idle when the air conditioner's on, or with it off as well?
Old Apr 28, 2008 | 08:35 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I thought this would be about girls...
Old Apr 28, 2008 | 09:35 PM
dandennis123
it started happening after i got some parts on
Old Apr 28, 2008 | 09:38 PM
Ancient Mariner's Avatar
Ancient Mariner
I was thinkin' graven images. But then, I'm older than you. Pre-tv, even.
-skip-
Old Apr 28, 2008 | 09:46 PM
ScottRiqui's Avatar
ScottRiqui
Well, don't keep a secret - what mods/maintenance were you doing right before the problem started?
I would start by check all of the vacuum hoses under the hood to make sure they haven't come loose or developed cracks/splits. A small vacuum leak can cause a low, rough idle - even if it's not bad enough to throw an engine light.
Once you have the engine speed up above idle, does it feel okay?
Old Apr 28, 2008 | 09:54 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
-skip-
grav·en // Audio Help /ˈgreɪvən/ Pronunciation Key - Show Spelled Pronunciation[grey-vuhn] Pronunciation Key - Show IPA Pronunciation –verb
1.a pp. of grave –adjective
2.deeply impressed; firmly fixed.
3.carved; sculptured: a graven idol.
Old Apr 29, 2008 | 12:37 AM
dandennis123
i did all mods above within the last month and thanks ill check out my hoses
Old Apr 29, 2008 | 10:35 AM
Ancient Mariner
#3. Now I'll stop futzin with this thread.
And dandennis: what parts did you put on just prior to the problem? Inquiring minds want to know.
-skip-
Old Apr 29, 2008 | 11:03 AM
blkkouki's Avatar
blkkouki
i may be totally wrong and someone please correct me if i am, but the car will take a ltitle time to adjust to the bolt ons especially the pulley, i dont know from experience for my pulley was on when i got my mini, but i have searched and read many times on the pulley doing that and should pass as the ecu starts to accept the extra air flow and adjusts accordingly
Old Apr 29, 2008 | 11:15 AM
dandennis123
unichip, alta 17% sc pully, magnaflow muffla with a lil bit of piping, msd coil pack and dinan intake no silicone hose i put these on with in the last 3 weeks
Old Apr 29, 2008 | 03:21 PM
blkkouki's Avatar
blkkouki
it may even just be the unichip, the a/f ratio for idle may be off
Old Apr 29, 2008 | 03:57 PM
ScottRiqui's Avatar
ScottRiqui
The ECU does "adjust" for things like A/F ratio, engine octane, ambient temperature, etcetera, but all of those adjustments are virtually instantaneous and being made continuously as you drive the car. I don't think the ECU does any long-term "learning" or "adapting" to your driving habits or engine modifications.
Old Apr 30, 2008 | 12:58 AM
Ancient Mariner
Agreed. The sensors read various engine conditions, the ECU compares them to parameters, changes are made on the fly. No learning curve that I know of.
-s-
scfiveo
Sep 27, 2019 02:27 PM
navybsn
Oct 4, 2015 03:27 PM
micromini234
Sep 30, 2015 07:36 PM
Miniwaukee
Sep 29, 2015 09:22 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
