Time to replace my RF Tires
Old Aug 7, 2003 | 09:58 AM
aa3jy's Avatar
aa3jy
Have gone thru about 20+ pages on this Tire and wheel forum and got tired go'n any further. Looking to replace my Perrilli OEM Run flats..cant believe I only got about 12K on'em..Goodyear Eagles RSA's are about 8 lbs heavier and more expensive..Dunlop SP Sports lok like there are for summer only driving. Looking for a higher milage all wx tire and a bit less expensive than the OEMs.. suggestions??
Old Aug 7, 2003 | 12:15 PM
Alex@tirerack's Avatar
Alex@tirerack
forgive me, what is WX?
Alex
Old Aug 7, 2003 | 12:19 PM
bbmykal's Avatar
bbmykal
Hmmm, maybe he means all weather/season. That's what the Eagles are. and he just wants higher milage.
Old Aug 7, 2003 | 03:33 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Are you trying to use these tires for snow as well?
For general use non runflats some people like:
Yokohama AVS ES100 or Bridgestone Potenza Pole Position S-03
Both are worth a look and available at tirerack.com
Old Aug 7, 2003 | 03:49 PM
Alex@tirerack
Bridgestone RE 950 45k $142 ea!
Call me to order!
Alex
Old Aug 7, 2003 | 03:53 PM
aa3jy's Avatar
aa3jy
Yes..I'm looking for an all season, higher milage tire to replace my OEM's. The Perellies are horrible in the snow and the milage is atrochous (less than 12K). However the Goodyear 'Eagle' RS-A EMT is more expensive and about 8 lbs heavier per tire. Any other worthy tire to look at?
Old Aug 7, 2003 | 04:52 PM
Alex@tirerack
This is a great performace all season tire, 950. What charteristics would you like that it doesn't have?
Alex
Old Aug 8, 2003 | 05:40 AM
aa3jy's Avatar
aa3jy
>>Alex
Hi Alex,
Didn't see my tire spec on your website for 205/45R 17 for the Bridgestones..also the site said they are 'H' rated..also are they Run Flates?
Thanks,
Clay
Old Aug 8, 2003 | 10:38 AM
Alex@tirerack
they are non runflats.
they are 215/45/17 - many more choices in that size!
Alex
Old Aug 8, 2003 | 11:37 AM
orbhot's Avatar
orbhot
You do not want to try putting H rated tires on the MCS unless you drive like a grandma.
Old Aug 9, 2003 | 05:18 AM
aa3jy's Avatar
aa3jy
You don't know my Grandma..she deffinitly not 'H' rated..more like a 'Z' rated
Old Aug 11, 2003 | 05:09 AM
Blue Brummie's Avatar
Blue Brummie
For those of you swapping out Run Flats for non-Run Flats, are you just accepting the risk of a blow out, or are you taking other measures?
Spike
Old Aug 11, 2003 | 08:30 AM
Alex@tirerack
try a seach to see the tactics.
often a cell phone - a roadside plan, a 12v comprssor, and a can of fix'o flat.
I think in the lower profiled sides 950 is a great choice, if you want all season, and dont need razor sharp steering - very comfortable !
Alex
Old Aug 11, 2003 | 08:36 AM
Blue Brummie
>>Alex
Thanks Alex. That's the way I was leaning, but just looking for some other ideas.
Old Aug 11, 2003 | 04:58 PM
aa3jy's Avatar
aa3jy
>>Spike
probably has been answered on previous posts..but can I replace non-run flat tires on Run Flat rims?
Old Aug 11, 2003 | 05:11 PM
W3IWI
Alex -- you recommended
But when I use your website, I don't see the RE950 pop up under either 16" or 17"
Am I doing something wrong?
Tom
Old Aug 12, 2003 | 05:43 AM
Alex@tirerack
Yes, with no issue!
Alex
Old Aug 12, 2003 | 05:47 AM
Alex@tirerack
Hi Tom
Try seaching custom, size 215/45/17
or see it here
Re 950 H rated
or
RE 950 W rated
Alex
>>Tom
Old Aug 12, 2003 | 06:33 AM
aa3jy's Avatar
aa3jy
>>Tom
Yo Tom,
Got any Ham gear in that Mini yet..
Clay AA3JY
Old Aug 12, 2003 | 06:35 AM
aa3jy's Avatar
aa3jy
What kind of milage would I'd expect on these tires?
Old Aug 12, 2003 | 08:00 AM
Alex@tirerack
45,000 miles
Alex
Old Aug 12, 2003 | 08:57 AM
aa3jy's Avatar
aa3jy
>>45,000 miles
>>Alex
I guess anything is better than the 12K on the Perellies OEM's
Old Aug 12, 2003 | 09:41 AM
Alex@tirerack
Rotation every 3-4k will help dramaticalli, even on the OE Eufori
Alex
Old Aug 13, 2003 | 05:22 AM
aa3jy's Avatar
aa3jy
>>Alex
>>>>I guess anything is better than the 12K on the Perellies OEM's :smile:
Old Aug 13, 2003 | 08:00 AM
Graham's Avatar
Graham
Alex,
My Mini Cooper S came with 205/45/17 runflat tires.
Is it possible to fit 215/40/17 tires without upseting the wheel alignment and loading?
The roll diameter is slightly less.
