R50/53 Fuse "F40" keeps blowing!
Old Apr 8, 2008 | 02:36 PM
pimpedout97x's Avatar
pimpedout97x
i replace it and it keeps blowing everytime i start the car! i have no headlights or speedo/tach at the moment. someone help!!!!
Old Apr 8, 2008 | 06:25 PM
pimpedout97x
anyone? i really need help..the speedo is the least of my worries. i want the headlights working. i even took out the wires that i extended for the a/c panel, no wires are touching, and it still does this. i really dont know what to do at this point. im getting worried...
Old Apr 8, 2008 | 07:11 PM
nypepper's Avatar
nypepper
check the toggle switch wires
Old Apr 8, 2008 | 07:15 PM
pimpedout97x
those are plugged in as normal, would that have anything to do with it? i didnt cut into those.
Old Apr 8, 2008 | 07:52 PM
Modshack's Avatar
Modshack
Umm...That implies you cut into something....What was it?
Old Apr 8, 2008 | 09:49 PM
Ancient Mariner's Avatar
Ancient Mariner
Fer sure. If you were poking around somewhere with sharp thingies, you need to go back to that point and 'unfix' whatever you were fixing.
-skip-
Old Apr 9, 2008 | 06:08 AM
pimpedout97x
https://www.northamericanmotoring.co...d.php?t=135387
Old Apr 9, 2008 | 06:19 AM
Modshack's Avatar
Modshack
Looks to me like you created your own nightmare. I don't think anyone here is going to be able to help you....
Old Apr 9, 2008 | 06:23 AM
pimpedout97x
this isnt good.
Old Apr 9, 2008 | 06:30 AM
jabell2r's Avatar
jabell2r
Coordinator :: M2C2
Gotta agree with skip. Go back and undo what you did and keep your fingers crossed.
Good Luck
Old Apr 9, 2008 | 08:46 AM
peanut_man's Avatar
peanut_man
Oh man, bad, very bad. You shouldn't have cut into wirings unless you know exactly what they were. Go get yourself a Bentley manual ASAP! Before you fried something very expensive... like ECU.
Old Apr 9, 2008 | 10:17 AM
Ancient Mariner
After reading your other post, I'd say look at those two red/white wires that you weren't sure of.
I gotta tell ya though: I was an electronics tech in the service, and I'm pretty comfortable with my skill level. BUT and I must stress this: BUT I would never, ever dive into the wiring with the complexity of the MINI without a wiring diagram, a test meter, and a lot of pre-study of the system I'm making changes to.
It is no longer a system that runs 12 volts from point A to point B. Almost everything in the car goes thru some type of controller and the wiring is as much a communication system as it is a power/control system.
Beware of what you do there. If you screw up and let the smoke out of the black box, it's really hard to get it back inside.
(sorry about the rant)
-skip-
Old Apr 9, 2008 | 11:14 AM
pimpedout97x
OMG, i figured it out, and i feel very stupid LOL.
the toggle switch panel wiring harness was plugged in backwards LOL. the switches all worked, i just guess that it kept blowing that fuse. all is good now. i will continue to relocate the a/c, i still need to figure out those red/white wires though. but im glad that wasent the issue. just had the switch panel in wrong lol
PsychoRallye
21
Feb 17, 2019 06:08 AM
minimofo
Dec 26, 2015 12:03 PM
mni928
Nov 9, 2015 07:38 PM
Chefben63075
Oct 1, 2015 12:04 PM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
