R50/53 exhaust leak, possible sources?
Old Apr 4, 2008 | 07:53 AM
ggv's Avatar
ggv
hello all
under moderate to hard acceleration I am getting exhaust in the interior of my Mini, both with the windows up and down. It is an '03 MCS, with a MiniMadness cold air intake & cat-back.
There was an initial leak in the system (where the straight pipe joins the pipe that splits into two, to go to the mufflers) that was caused by the clamp being stripped; this was noticeable audibly as a "spluttering" noise as well. I have had this fixed, and the system sounds completely leak-free, but I am still getting exhaust in the cabin under hard acceleration.
Any thoughts?
I should mention that the dealer installed a new flywheel under warranty, so I think I can assume that at some point the exhaust was disconnected at the engine exhaust manifold point.
cheers
greg v.
Old Apr 4, 2008 | 08:53 AM
kenchan's Avatar
kenchan
check your mid pipe connection.
Old Apr 4, 2008 | 09:02 AM
ggv's Avatar
ggv
Could it be leaking from there enough to get into the cockpit yet not be audible as a leak?
Not having had much of a chance to get familiar with my Mini's underside (yet), would this be where the aftermarket components couple to the factory pipe?
cheers
greg v.
Old Apr 4, 2008 | 09:05 AM
kenchan's Avatar
kenchan
yep, that's the spot. it might be loose. or you just need
a new gasket.
Old Apr 4, 2008 | 09:06 AM
03BRG's Avatar
03BRG
Have a friend with gloves block the tail pipe, the back pressure will make the leak show itself.
Old Apr 4, 2008 | 09:17 AM
ggv's Avatar
ggv
thanks guys, I really want to get this fixed!
cheers
greg v.
Old Apr 16, 2008 | 04:03 PM
ggv's Avatar
ggv
minor update, I had my Mini back at the local Midas, and they went over it with a fine tooth comb and could find nothing. I have an appointment to get it back into the dealer, but was wondering again if anyone had any ideas on any likely culprits.
Since the dealer had the transmission out for the flywheel replacement, I still feel that it is somewhere at the bottom of the exhaust manifold.
any helpful info appreciated.
cheers
greg v.
Old Apr 16, 2008 | 08:47 PM
afinley's Avatar
afinley
have you modified the divider panel behind your airbox?
Old Apr 17, 2008 | 10:28 AM
ggv's Avatar
ggv
Indeed, it has been modified. The Stage 2 kit I got from Mini Madness included a reprogrammed ecu, smaller supercharger pulley, a s/s cat back, and the intake as shown here:
http://www.mini-madness.com/index.as...WPROD&ProdID=9
which includes a divider with an enlarged hole.
You think this might have something to do with exhaust coming into the interior? If so, would that not mean that there was exhaust gases present somewhere in the engine compartment, and thus leaking from somewhere?
gv
Attached Thumbnails exhaust leak, possible sources?-cooper-s-intake-blue2.jpg
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
