Navigation & Audio FM Interference after SIRIUS Radio Install
Old Apr 2, 2008 | 05:42 PM
robrob's Avatar
robrob
I just installed a Sirius Stiletto 100 in my 08 Mini Cooper using the Stiletto car install kit and the standard SMB antenna extension to the under seat antenna wire.
Sirius works great but now when I bring up the Mini's standard FM radio I get a lot of intermittent interference--even with strong stations. I checked and confirmed that the Stiletto's FM transmitter is off.
Anyone have this problem or have any suggestions?
Thanks in advance,
Rob
Old Apr 3, 2008 | 09:38 AM
robrob's Avatar
robrob
Update: I get the FM interference whenever the Stiletto is powered. If I unplug the power cable the interference goes away, but if I simply put the Stiletto into sleep mode the interference remains. I forgot to try the "hard off" option.
It seems that the Sirius antenna is active (electrically powered) whenever it senses a receiver hooked up to it, which interferes with the FM antenna in the combo FM/AM/GPS/Satelite antenna. With the built in Sirius receiver it must completely power off when any other audio source is selected on the Mini's audio control panel.
But I still have to ask, has anyone else had this problem or is it a newer build issue?
Rob
Old Apr 3, 2008 | 10:00 AM
TheBigNewt's Avatar
TheBigNewt
Makes perfect sense to me.
Old Apr 3, 2008 | 10:15 AM
glangford's Avatar
glangford
Try using an aftermarket antenna connection instead of the car's.
Old Apr 3, 2008 | 10:44 AM
robrob's Avatar
robrob
That would definitely solve the problem and the Stiletto car kit came with an external antenna but I don't want another antenna on the roof.
Old Apr 3, 2008 | 11:27 AM
spfdhed's Avatar
spfdhed
I have a XM sportscaster via the aux in port and I use the SMB factory antenna and toggle back and forth btw xm and fm without any interference. How did you power the sirius? Maybe a ground loop interference. I would use a "add a fuse" and directly hotwire to 12 volt.
Old Apr 3, 2008 | 05:24 PM
robrob's Avatar
robrob
That's very true, I hope you're right. I'm temporarily powering it with the cig plug, but I have an add-a-circuit in the mail. A ground loop would explain why the interference is present until the cig plug is pulled.
I'll try powering the Sirius receiver from a separate 12v battery too and see what that does. I'll post here if either fixes the problem.
Thanks for the help guys,
Rob
Old May 4, 2008 | 07:55 AM
robrob's Avatar
robrob
It was a power ground loop. When I hardwired in the Sirius receiver using the "Add-a-Circuit" the FM radio receives just fine. It's strange that the supplied Sirius auto kit power cable plugged into the stock Mini cigarette lighter would have such a bad ground loop.
Rob
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
