Suspension How tight on M7 STB
Old Mar 26, 2008 | 05:30 PM
freeskier's Avatar
freeskier
How tight on M7 STB
recently bought an M7 stb for my 02mcs and wantd to kno how tight to torque the mounting bolts i ad heard 25lbs but i wasnt sure.
Old Mar 26, 2008 | 07:45 PM
AutoXCooper.com's Avatar
AutoXCooper.com
25 is good.
Old Mar 26, 2008 | 07:54 PM
Some Guy's Avatar
Some Guy
25 is about right, I torqued mine to 23 and havent had problems. It is important to not over torque these as there is a possibility of snapping the studs off if you over torque.
Old Mar 26, 2008 | 10:23 PM
verveAbsolut's Avatar
verveAbsolut
Directions call for 25 lb/ft.
- Matt
Old Mar 27, 2008 | 05:51 AM
freeskier's Avatar
freeskier
ok thanks guys. some locktight and im all set
Old Mar 27, 2008 | 06:01 AM
eager2own's Avatar
eager2own
+1 -- don't ask how I know
Old Mar 28, 2008 | 09:50 AM
Petrich's Avatar
Petrich
25 ft/lbs max, max
The recommended tightening torque is very important. The threaded inserts will strip at a torque not much higher than 25 ft/lbs. The bolts won't break, but the inserts will fail. Then, you'll have the challenge of removing the stripped insert and replacing it with a new one. Not worth the aggravation of over torque.
Also, don't Locktite the bolts until you have driven the car and re-torqued the bolts. What happens is that the inserts will crush a little more from use and the whole assembly will settle and the bolts will loosen a bit. It is not uncommon to need to re-torque the bolts after use. This is NOT an M7 problem, it is a fact of life with the inserts set into sheet metal with hand tools.
Hope this helps,
John Petrich in Seattle
MGBill1186
Oct 2, 2015 06:54 AM
rt808
Sep 25, 2015 01:59 PM
YoloSapien
Sep 25, 2015 07:12 AM
Systemlord
Sep 19, 2015 02:57 PM
theateist
Sep 16, 2015 07:22 AM
