Seat Memory Problem
Old Mar 25, 2008 | 05:31 AM
Loony2N's Avatar
Loony2N
Seat Memory Problem
It seems that both my front seats have lost their memory. You know that neat feature that returns the seats to their original location on the tracks after you slide them forward to let some one in or out of the back seats? Well, neither of my seats do that anymore. Am I forgetting to do something, other than attempting to slide the seat back, or is there a way to reset it, other than taking it to the dealer, who will, no doubt, tell me they found nothing wrong?
Old Mar 25, 2008 | 05:45 AM
korby's Avatar
korby
In the seat track there is a metal part that moves and it can get flipped up . Pull your seat forward and you'll see it , just flip it back down .
Old Mar 25, 2008 | 05:48 AM
Loony2N's Avatar
Loony2N
Thanks! Is it something obvious? I don't want to pull the ejector tab by mistake. Great! I'll have to move the seat again and then spend 20 minutes making sure it's in the exact same position.
Old Mar 25, 2008 | 05:53 AM
korby's Avatar
korby
It is obvious it's the only thing thats in the track that moves other than the seat . Mine didnt work when I got it . You flip it up or down I dont remember but thats the thing that makes it work .
Old Mar 25, 2008 | 05:58 AM
Loony2N's Avatar
Loony2N
Reminds me of something else... After it got played with, it didn't work for a little while........
Old Mar 25, 2008 | 09:42 AM
pyskacz's Avatar
pyskacz
Hmmmmm
Old Mar 25, 2008 | 01:08 PM
JeffreyC's Avatar
JeffreyC
I'm sure there is a moral to that story somewhere.
Old Mar 25, 2008 | 01:10 PM
Loony2N's Avatar
Loony2N
moral probably isn't the right word....
Old Mar 25, 2008 | 01:53 PM
-Vampyre-'s Avatar
-Vampyre-
I have found that when moving the seat back to the memory position, you have to slide the base back and then tilt the back up. Failing to do that would lock the base as soon as the back was fully tilted, but the next time you tilt the seat forward if you slide the base first it goes back to the initially set position.
Old Mar 25, 2008 | 06:01 PM
r56mini's Avatar
r56mini
+1
Old Mar 25, 2008 | 06:10 PM
JohnJohn's Avatar
JohnJohn
+1
Always let the base(butt) slide all the way back before up-righting the seat back(back).
Old Mar 26, 2008 | 05:23 AM
Loony2N's Avatar
Loony2N
Yeah, I know that part. And I looked and didn't see this "obvious" tab. Where exactly is it?
Old Mar 26, 2008 | 07:13 AM
korby's Avatar
korby
Slide your seat forward and look behind it , its shiny silver thing in the black track you cant miss it unless your missing it .
Old Mar 26, 2008 | 07:18 AM
Loony2N's Avatar
Loony2N
Thanks. I was dressed for work when I looked, so I couldn't manuever well.
Old Mar 26, 2008 | 09:11 AM
korby's Avatar
korby
They got you in the straitjacket again ?
Old Mar 26, 2008 | 11:08 AM
Loony2N's Avatar
Loony2N
As usual.
Old Mar 26, 2008 | 11:56 AM
msh441's Avatar
msh441
Nothing in the locking tab "flips up" in any way. It just slides forward or back on the track.
To fix this issue, slide the seat all the way forward.
When you see the silver tab in the track, slide it as far forward in the track as you can (by hand).
Fold the seat back into place (before moving back on the track).
The next time you move your seat back, it will re-engage the locking tab and you should be good to go.
Old Mar 26, 2008 | 08:52 PM
Minidrivr's Avatar
Minidrivr
This solution worked for me a few months ago. For some reason that silver tab just got out of wack with the seat. I pushed it as far forward as I could using a long screw driver. It has worked fine every since!
Old Mar 27, 2008 | 06:52 AM
Loony2N's Avatar
Loony2N
I was able to find the tab and reset it. Thanks all. However, the one on the passenger side did not just slide up. I had to depress the silver lever first, so I guess it is somewhere between a thing that just slides and having to flip the tab.
Old Apr 2, 2008 | 07:25 PM
ANT818's Avatar
ANT818
That was helpful. Now I can let the kids back into the car.
Getrieben
Sep 12, 2024 07:03 AM
Mini'mon
Aug 26, 2015 01:02 PM
Zettinger
Aug 25, 2015 04:04 PM
bseiden
Aug 15, 2015 10:16 AM
