R55 SPRINGS!
Old Mar 24, 2008 | 09:59 AM
William Blake's Avatar
William Blake
SPRINGS!
What springs lower the MOST?
H&R has a kit for the Clubman, lowers the car by 1.4 inches (about 3.6 cm)
Any others that lower even more?
Thank you in advance!
Old Mar 24, 2008 | 11:10 AM
William Blake
How about KW springs? Any good?
Old Mar 25, 2008 | 03:23 AM
William Blake
It seems H&R lowers the most at 1.4 inches.
Good to know!
Old Mar 26, 2008 | 04:59 AM
xBoXlOvEr's Avatar
xBoXlOvEr
As you know, I have the 3cm for the r56 and it sits soooo low... I think 3.6 will be excesive but I would like to be lower in the front, as the rear is now...
Old Mar 26, 2008 | 05:26 AM
William Blake
You have R56 H&R springs right? They lower exactly as much as the R55 H&R Springs.
Old Mar 26, 2008 | 08:36 AM
xBoXlOvEr's Avatar
xBoXlOvEr
So... why H&R have developed a kit for Clubman? :S
Old Mar 26, 2008 | 12:36 PM
William Blake
Clubman is 70 kg heavier, ok it's virtually nothing but that could be the reason. Also the Clubman has different dampers in de back.
Old Mar 27, 2008 | 06:13 PM
Robsreef's Avatar
Robsreef
On Alta's website, the are now selling the H&R springs for the clubman for only $249.
Old Mar 28, 2008 | 12:31 AM
William Blake
I already have the H&R springs for R55 on order
Will post pics as soon as it is mounted.
Old Mar 29, 2008 | 05:20 AM
xBoXlOvEr's Avatar
xBoXlOvEr
Ok, William... We'll waiting for your pics and impressions...
Old Apr 12, 2008 | 04:06 AM
William Blake
Any experiences with the Eibach kit? Lowers 1.2 inch in the front (about 30mm) and only 0.8 in the rear. (why?)
On a normal MINI it's 1.2 in the front and 1.2 in the back..
Old Apr 24, 2008 | 09:47 AM
klt's Avatar
klt
They lower the back a little less because they want to make the car have an even drop.
I will be getting a set of pro-kits. From personal experience, they've been the best mix in functionality/drivability/looks every time I've used them.
Anything lower and you might into the dark place of camber issues, uneven tire wear, and over-stressed stock shocks.
Old Apr 25, 2008 | 05:24 PM
azminiman's Avatar
azminiman
I too have H&R springs for my Clubman sitting in my garage. Samsung arrived at the dealer on Wed night, should have Sunday or Monday.. Will install the springs and 215/40 18s the same day... Will post when done
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
