R55 Brake Pulsar Install on Clubman
I recently got the GoMiniGo.com third brake light Pulsar. You can find it here. Here is a pictorial of my install since there was no instructions for the Clubman as I write this.
First, you need a T-25 TORX driver, wire cutters, wire strippers, and small jewelers flathead screwdriver. Do not take off the seal that goes around the door area. It has a sticky black goo that gets everywhere inside and it is not necessary to remove to do the install.
Remove the brake light assembly that is held on by 8 TORX screws under the rain rail.
Brake light assembly removed. Two things here. First is a tube for the rear window washer jets. The other is the brake light wiring.
Here is a close up of the wiring before I started.
Wire harness plug removed. It pushes to the right with a little pressure. This shows the under side of the plug. It has a small prong that latches it to the assembly.
I found a spot that the Pulsar would go that doesn't interfere with the latching of the plug. I cut the wire half way between so that both sides had more than enough wire to go into the Pulsar.
Pulsar connected to the brake light side wiring.
Pulsar connected to both sides of the wiring harness. I then stuck it with the included adhesive very carefully in the spot I had chosen.
Plug re-attached to the brake light assembly.
The brake light assembly finished and the wires re-routed to the factory locations. Slide the unit back on to the car. (Make sure you guide the rain rails into their notches correctly) Screw together. Done!
Last edited by AlexMoultonIsMyMan; Jul 1, 2013 at 06:09 PM. Reason: Repaired Image Links
I sold my Clubman about 2 years ago, but I still have the photos, just not on Flickr. Here is the link to them in my Dropbox.
Great pics. Wondering if you could tell me if you thought this was a worthwhile mod or just distracting? Seems good and its relatively cheap. I'd like to buy it but I'd like to hear from anyone who has experience with it firsthand.
Via iPhone using NAMotoring
Driving my new MCS from southern NJ to upstate NY, I noticed that cars behind me really backed off whenever I applied the brakes. Of course, I have no way of knowing how much effect the Pulsar actually had, but it did seem like people were paying more attention to my braking than they used to.
Thanks for the photos. A tremendous help, although I installed the module (BLP) that looks like a large thimble. 3 wires: Blue goes to MINI Brown and Red & White go between a cut yellow-pay attention to the BLP directions for which way the Red connects and which way White connects. If they're backwards 3rd brake light will not pulse; just reverse them if this happens (duh, how do I know?).
squawSkiBum
Oct 2, 2015 09:21 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
