The suspension should be identical, save perhaps some damper or spring rate tweaks for the weight change. I'd imagine that H&R's would be perfect for the Clubman. On the hardtop the rear end sits a bit too high, so on the slightly heavier Clubman they'll have perfect stance!
got my HR springs from alta last week, they are a different # from the R56. Not sure if that really means they are differant. H&R person says yes.. just a little stiffer to support the extra weight.,, they sitting in garage waiting for Samsung to show up!!
Reason: add
dont need coil overs.. alta has the r55 springs.. thats all I need. Just want to elimiate the 4x4 stance.. If I have a need for better handling,, I just take the GP that day
