R52 Keeping Rear Window Clean
Old Mar 11, 2008 | 01:01 PM
BigGuy25's Avatar
BigGuy25
This is my 1st winter with a MINI cabrio. I live in Northeast Ohio where, in the winter, the roads seem to be in a constant state of snow, slush and road spray causing a problem with visibility through the rear window. I can clean the rear window and, within a mile or two, the window is almost impossible to see through again. Do others share this problem? Is there any secret that helps to keep it clean.
Old Mar 11, 2008 | 01:02 PM
talus's Avatar
talus
I put mud flaps on mine and it greatly reduced this problem. You still get some stuff there but it isn't nearly as bad.
Old Mar 11, 2008 | 01:04 PM
eager2own's Avatar
eager2own
I guess telling you to keep the top down in the winter won't help, huh?
Old Mar 11, 2008 | 02:10 PM
BigGuy25's Avatar
BigGuy25
Was the mud flap made for the MINI? Are they easy to install?? How do tey look???
Old Mar 11, 2008 | 02:13 PM
talus's Avatar
talus
Yes made by MINI. I had the dealership install them. I think they are barely noticable. Totally worth it.
Old Mar 11, 2008 | 02:21 PM
BigGuy25's Avatar
BigGuy25
Talus ... thanks, I'll get it done!!!!
Old Mar 23, 2008 | 04:35 PM
bradclark's Avatar
bradclark
Any chance you could provide a picture or two?
Old Mar 24, 2008 | 05:27 PM
BigGuy25's Avatar
BigGuy25
FYI .. in a private message response, Talus told me that he had them put on the front and back. The dealer told me that the front flaps are something like $20 and the rear are around $40. I'm not sure what they charge to install.
Old Mar 24, 2008 | 06:35 PM
joshamman's Avatar
joshamman
can't imagine installing mud flaps is hard
would love to see some pics of them on
im in Michigan, so i have the same dirty-boot syndrome going. I just use my side mirrors
looks like it depends on your year for rear ones. Mini made them for pre2005 cooper ONLY , and now for the next gen 07+ both cooper and S. Not sure if it would be possible to retrofit them :(
Old Mar 24, 2008 | 06:46 PM
joshamman's Avatar
joshamman
from out motoring. link to the flaps:
http://www.outmotoring.com/mini-coop...mud-flaps.html
http://www.outmotoring.com/mini-coop...mud_flaps.html
Old Mar 24, 2008 | 06:49 PM
MiniMaybee's Avatar
MiniMaybee
Good luck mate. Best you can do is get some Multivex mirrors and learn not to look out the rear. Guess that's why the tin tops have a rear blade, but us poor cabrio owners are destined to never look back - onward, forever forward!
Old Mar 24, 2008 | 06:58 PM
Jeff S.'s Avatar
Jeff S.
TRhe mud flaps from MINI are great. The blend into the black and mount so that on the side view they are just after the reflectors. From the rear they make the car apper lower and wider. They protect the vehicle from most whell throw off. The rear one require the back wheels being removed for installation.
Old Mar 25, 2008 | 02:57 PM
iblack's Avatar
iblack
You put mud flaps on your cabrio? You don't happen to have the aero package do you? If so, from where did you get them?
Old Mar 25, 2008 | 05:46 PM
bad venge's Avatar
bad venge
I've had good luck with waxing my rear window with Collonite wax, even a good coating of RainX will help
Old Mar 30, 2008 | 03:46 PM
Marylander's Avatar
Marylander
uhhh, having major problems keeping the rear clean. my service advisor did not think the rear mud flaps would help that much and weren't too attractive. i almost always back into parking spots because i'm terrified of backing out of a spot.
how about a rear mud flap pic?
Old Mar 30, 2008 | 03:52 PM
MGCMAN's Avatar
MGCMAN
Damn BG, this is a simple fix. You've got a Cabrio, right? Top Down Motoring = no salty road spray gunking up the backlight, dude. Best to buy a good set of earmuffs and a good anorak though.
Old Mar 30, 2008 | 06:31 PM
BigGuy25's Avatar
BigGuy25
MGCMAN -- LOL. I wish I could keep the top down all the time. This has been one hell of a winter. I shoveled 7 inches of "springtime" off the driveway on Easter weekend. Today it finally got up to 53 degrees. I put the top down, installed the windscreen, and, you guessed it .... IT STARTED TO RAIN!!!
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
ccccPUNISHER
Aug 15, 2015 01:35 PM
bugeye1031
Aug 15, 2015 08:14 AM
