Embedded URLs... b0rked
If one wants to use the
button and embed a link like this, it works fine for the link, but the hyperlink part doesn't stop after the insert (see how my whole sentence becomes part of the link? It means you can't type out a reply normally, but have to write your response and then go back and insert the links afterwords - this isn't a vBulletin issue, it's a NAM one. This isn't a problem on other boards.
I'm using Firefox by the way. It's like the</a> is missing in the HTML coding.
button and embed a link like this, it works fine for the link, but the hyperlink part doesn't stop after the insert (see how my whole sentence becomes part of the link? It means you can't type out a reply normally, but have to write your response and then go back and insert the links afterwords - this isn't a vBulletin issue, it's a NAM one. This isn't a problem on other boards.I'm using Firefox by the way. It's like the</a> is missing in the HTML coding.
actually, it closes fine, but it appends the inserted URL onto the end of www.northamericanmotoring.com, rendering the link dead. ex: northamericanmotoring.com/forums/www.cnn/com is how it links :(
Dan - I have a non-modified version of vBulletin on my dev machine and it always works this way with Firefox. From my testing I've also seen it do the same thing with bold, underline, etc. If you don't have at least a space immediately after the word you are bolding, linking, etc. it thinks that it needs to continue whatever was selected as the markup option.
Mark
Mark
I havent had an issue with the links, I manually type in the code tags myself.. but maybe I should try using the button options...
nah.... I have seen IE do odd things with formatting and page breaks. When I do web development It sux cause IE has separate rendering options as opposed to Firefox, Opera, Safari, etc...
uber l33t = hand coding
Mark
Mark
what's the deal with the NAM URL that gets embedded (examples above)? That seems inconsistent...can't always make it work or keep it out either.
In my non-modded dev install if I create a post and select a word to link to a URL it expects a fully qualified URL using http:// plus the all the rest of things. If, however, I leave out http:// and make it a relative URL such as "/index.php" it will automatically include the domain of the site. I tried this down in the test forum and it appears to work the same way.
Mark
Mark
http://www.cnn.com
click
default is http:// (add the rest)
I see...overwriting the default and using www.cnn.com for example appends to the NAM space. Interesting. No, I'm not a n00b
I've only had these issues here...wonder if the other boards have been tweaked to make it literal.
click
I haven't run across anything that talks about tweaking this. I noticed this behavior a long time ago and just changed the way I link slightly to accommodate it. If there is a vBulletin add-on to make this more obvious it would certainly be useful.
Mark
Mark
Slightly Related--have you seen the feature that uses the destination links Title as the thread link? Over on Caymanclub.net that I sponsor, when anyone posts a link in a thread, it grabs the title of the page of that link and puts it as the LINKED ITEM in the post, as well as the link to that item.
At first I thought it was annoying because the link names were fixed, but then I realized that as long as the pages are named properly, it's a pretty good feature. Keeps link titles consistent and makes it easier.
http://www.caymanclub.net/cayman-car...octaneguy.html
I can still edit the link to tweak it on the post if needed, but it makes link insertions very easy.
Here's the results from copying and pasting an eBay and RealOEM URL:
eBay Motors: Mini : CLUBMAN (item 260218800772 end time Mar-16-08 08:39:08 PDT)
RealOEM.COM BMW R53 Cooper S JOHN COOPER WORKS TUNINGKIT 210 HP
In most cases I end up having to tweak the title, unless I remember to uncheck the Automatically retrieve titles from external links option
