R50/53 Tire wear and wandering
Old Mar 10, 2008 | 07:48 AM
MDK's Avatar
MDK
I've noticed the outsides of my front tires are getting pretty smooth- I've tried to keep the pressure regulated (too much aggesive cornering!?) and I have also noticed the front ends wants to wander under acceleration and at low speeds lately. It's kind of like torque steer but might also be realted to the tires following the road surface.
So it looks like new tires pretty soon but do I also need to have the front end addressed?
Old Mar 10, 2008 | 08:01 AM
AstroBlackS's Avatar
AstroBlackS
Check the Front Lower Control Arm Bushings. They may be shot.
Old Mar 10, 2008 | 08:16 AM
MDK's Avatar
MDK
Will do- I forgot to mention I have just under 15k on the clock- seems kind of early for this no?
Old Mar 10, 2008 | 02:01 PM
kenchan's Avatar
kenchan
alignment?
Old Mar 10, 2008 | 02:50 PM
Jhud's Avatar
Jhud
set your toe, make sure everythings tight and get some tires, nuff said
Old Mar 11, 2008 | 07:50 AM
MDK's Avatar
MDK
I've never set a toe- is this something you do on your own or do you have it done?
Old Mar 11, 2008 | 07:57 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
It has to be done at an alignment shop. I would also consider getting some camber plates. It will help even the wear across the tire, given the way we drive these cars, the plates can help double your tire life.
Old Mar 11, 2008 | 08:14 AM
Gromit801's Avatar
Gromit801
Your tires wanting to follow the irregularities in the road, is called "Tramlining," and it happens with brand new tires also.
Old Mar 12, 2008 | 12:55 PM
DaveTinNY's Avatar
DaveTinNY
Yeah, I noticed the Tramlining effect with my first set of Runflats and when I replaced them, it was gone on the same stretch of highway where I would noticed it. Or was it my imagination.....? I'll check again in about 10 minutes on my way home with the new snow tires.
Old Mar 13, 2008 | 04:49 AM
shwagg
Also check and see if the top of the strut towers is mushrooming.
Waszak
Oct 21, 2017 05:55 PM
molala
Oct 2, 2015 01:53 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
jacehubbs
Sep 3, 2015 02:01 PM
Ntety
Sep 2, 2015 08:39 PM
