R50/53 Tech Help - Trying to figure out a noise
Old Mar 9, 2008 | 09:08 PM
Apex Chick's Avatar
Apex Chick
I have a 2005 R54 Mini Cooper S with the JCW package. It has an aero kit on it too. When I am driving and I touch the gas I hear a thunk thunk noise from the back passenger side. It's quiet enough I didn't notice it at first, but now that I know the noise is there it's driving me nuts. Anyone have any ideas?
Old Mar 10, 2008 | 06:13 AM
Jahmills's Avatar
Jahmills
Could be a number of things. Bad bushings in the rear suspension, loose shock mount, bad bushings in the rear sway bar, or even something as simple as a loose item in the battery box or rear side compartments. Start with those & then narrow it down. If your car is still under warranty the dealer will check it out for you.
Old Apr 18, 2008 | 08:44 PM
LordOfTheFlies's Avatar
LordOfTheFlies
It's your upper engine mount which is located on the passenger side. See if the mount leaked - you'll notice some dried up black oil around the area...
This should be covered under warranty. If not the part is about $70 + you need an E14 socket to get the bolt from underneath that holds it in place.
lweaver
Sep 17, 2024 08:22 AM
Colt45Magnus
Aug 27, 2024 05:03 AM
Supertractor3
Apr 7, 2017 11:16 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
Sailorlite
Sep 4, 2015 07:03 PM
