Suspension Koni Yellow Install Questions
Old Mar 6, 2008 | 09:50 PM
jblow's Avatar
jblow
Preparing to install Koni Yellows, couple of questions
- Will the Hazet 21mm tool work for tightening the front shock nuts?
- Is it better to reuse the OEM shock/strut nuts or the nuts and lock washers which come with the Konis?
Old Mar 7, 2008 | 02:16 PM
chuckt's Avatar
chuckt
- You need a 21mm socket/wrench for the rear, lower mounting bolt. The Koni top nut is a 19mm.
- As I remember, the OEM nuts are a different thread size than the Koni's.
Old Mar 7, 2008 | 02:25 PM
RedSkunk's Avatar
RedSkunk
I used the nuts that came with the Konis. Why not?
Old Mar 7, 2008 | 03:45 PM
sprp85's Avatar
sprp85
get rdy to drill out some OEM parts... PITA in my opinion...
Old Mar 7, 2008 | 06:38 PM
cpayne's Avatar
cpayne
Easy w/ a Drill Press and 15/32" Bit
https://www.northamericanmotoring.co...d.php?t=130116
Yes you need to use the nuts that come w/ the kit..they are 12mm
Old Mar 10, 2008 | 06:51 AM
jblow's Avatar
jblow
Got everything installed this weekend (Dinan suspension w/ Koni Yellows) - all went pretty smoothly. Drilling the rear washers and top hats was a piece of cake with a bench vise and drill. Thanks to all for the tips on installation - using a 2x4 to compress the front assembly during install was a great help
Old Jul 13, 2013 | 01:36 PM
EB DOS's Avatar
EB DOS
How'd you guys tighten the nuts down on the front? there's the large hex and the smaller one on top, But the top plate covers both so you cant get a wrench inside
Old Jul 13, 2013 | 05:10 PM
MINIdave's Avatar
MINIdave
I used an impact wrench, worked perfectly.....
squawSkiBum
Oct 2, 2015 09:21 AM
blackie
Aug 25, 2015 09:08 PM
Emnotek
Aug 13, 2015 05:47 PM
mini yellow-haa!
Aug 13, 2015 11:18 AM
