Suspension could someone shed some light...
Old Mar 4, 2008 | 06:06 PM
blue_bomber's Avatar
blue_bomber
alignment- could someone shed some light...
...on my alignment. they (grismer tire) couldnt adjust the rear toe because they didnt have the proper tool to do so. so, with these numbers, should i go somewhere else and have the rear toe adjusted or will it be fine as it is?
-shawn
Old Mar 5, 2008 | 05:30 AM
chadtoolio's Avatar
chadtoolio
You don't need a special tool....There is one, but I don't use it because it is a PITA. All you have to do is to loosen up the 3 16mm bolts and use a prybar to move the control arm....And yes, those toe numbers are extreme. You need to have it readjusted.
Old Mar 5, 2008 | 05:32 AM
chadtoolio's Avatar
chadtoolio
Double post
chadtoolio's Avatar
chadtoolio
BTW, the toe numbers for the front are not in factory specs either. The correct specs for front toe are: .09 plus or minus .03, so it should be anywhere from .06 to .12.
Old Mar 5, 2008 | 01:10 PM
blue_bomber
thanks, i guess ill call around and find someone that confirms they have the know how before i leave it. thanks again
dinomaniac
Sep 18, 2018 04:19 AM
silence2-38554
Sep 24, 2015 05:34 AM
Oilfieldtrash
Sep 23, 2015 03:02 PM
David.R53
Sep 13, 2015 03:44 PM
Andrew Namel
Sep 12, 2015 08:49 AM
