SuspensionSprings, struts, coilovers, sway-bars, camber plates, and all other modifications to suspension components for Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Okay, how about installing some really soft bushings...and, you can actually lengthen the endlinks - this will make the bar a little lazier since it reduces the leverage required to twist the bar.
I used ECE and found the part number, but when I checked the part number on DCS, it came back "part number not found".
I would have called on it, but ABS found one at Kass.
Sorry for any confusions. This part is a Special Order item but we can supply it. You will also need the correct bushing that we can also supply. Please give me a call and and I will take care of it! Call 800 946 2642 and ask for Don!
