Suspension Loose end at high speed Part II
Old Feb 26, 2008 | 10:22 AM
meb's Avatar
meb
Life has many aspects to it. We all tend to devot our time were we are needed and less so emersed in those things we love. Unfortunately for me, this creates a less than desirable atmosphere for experimentation, and more importantly, continuity.
A recent, and re-occurring glitch with my mini's brakes, may point to my braking stability - a sticky rear caliper caused in part by sticking E-brake line. I'll not jump into the details knowing this may apply to few. But it is worth a look. The inside right rear pad is almost totally worn despite a new looking outside pad.
Old Feb 26, 2008 | 10:40 AM
greengobln's Avatar
greengobln
i had the same problem on the other side. my left wore out prematurely. i replaced my lines with stainless steel and the fluid with ATE super blue. only time will tell if these changes are going to help. have you tried anything to correct it yet?
Old Feb 26, 2008 | 11:28 AM
meb's Avatar
meb
I haven't replaced the E-brake line, but the calipers are tended too often. SS lines were installed two years ago and the fluid is changed 2-3 times a year.
The calipers and pads are meticulously installed...so one wonders.
Old Feb 26, 2008 | 01:51 PM
k-huevo's Avatar
k-huevo
Happened to me https://www.northamericanmotoring.co...ad.php?t=87528
Old Feb 26, 2008 | 01:54 PM
goaljnky's Avatar
goaljnky
There you go. You are changing your fluid too much and are not giving it time to break in properly.
Old Feb 26, 2008 | 03:52 PM
bean's Avatar
bean
meb: i hope this is the solution to your problem. i don't think that it is mine. i've worn out 3 sets of rear pads equally.....inside to outside and left to right. i'll keep experimenting and let you know how it goes.....
greg
Old Feb 26, 2008 | 08:15 PM
succubus's Avatar
succubus
A bit of humor from an unexpected source! I like it.
Old Feb 27, 2008 | 12:15 PM
meb's Avatar
meb
Humor is a great thing...hey, you mak'n fun a me?
Kieth,
Dropping the exhaust sytem is a PITA! As soon as the weather warms up...
maestro39
Oct 27, 2015 02:38 PM
Pyrs
R55 :: Clubman Talk (2008+)
19
Sep 8, 2015 01:43 PM
xpunisherx
Aug 10, 2015 10:50 PM
