Suspension Adj. control arm installation
Old Feb 13, 2008 | 05:21 AM
jbroughton's Avatar
jbroughton
I'm getting ready to install adjustable control arms on my '03 S, and noticed that the upper inboard bolts don't look like they can be removed without hitting the gas tank. Do those bolts have to come all the way out, or will they pull back far enough to allow you to drop the control arms? Anything else complicated about this job? Any step-by-step instructions online anywhere?
Thanks!
Jeff
Old Feb 13, 2008 | 06:58 AM
AutoXCooper.com's Avatar
AutoXCooper.com
http://www.altaminiperformance.com/s...mpsus100v2.pdf
Old Feb 13, 2008 | 08:49 AM
Jason C's Avatar
Jason C
I ran into this when installing mine recently. Just something to lookout for.
https://www.northamericanmotoring.co...d.php?t=127524
Old Feb 13, 2008 | 09:16 AM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
i used an 1 3/4" extension and a small 3/8" breaker bar. It just holds the head of the bolt while i turn the nut on the other end. It is kinda tight but there is just enough room to do it. Then slide the bolt out the back.
I did the whole job in about 2 hours, including going to the auto parts store twice.
You will need to get an alignment afterwards.
Old Feb 14, 2008 | 05:37 AM
tools's Avatar
tools
Any body have torque specs for control arms?
Old Feb 14, 2008 | 11:14 AM
tools's Avatar
tools
I found out - 74#
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
maestro39
Oct 27, 2015 02:38 PM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
