JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW wing how-to
Old Feb 11, 2008 | 07:15 AM
Q-BAN's Avatar
Q-BAN
JCW wing how-to
Does anyone one have the insatructions for the Jcw Wing Install??
Old Feb 11, 2008 | 10:28 AM
Q-BAN's Avatar
Q-BAN
anyone, anyone? ...Buller, Buller??
Old Feb 11, 2008 | 10:33 AM
Jason C's Avatar
Jason C
I've seen it out there, but I can't find it right now. I'll let you know if I do.
Old Feb 11, 2008 | 10:38 AM
gnatster's Avatar
gnatster
That was really hard to find....
Google "Install MINI cooper Wing JCW"
First entry...
http://motoringfile.com/howto/JCW_Ca...of_Spoiler.pdf
Old Feb 11, 2008 | 10:46 AM
Q-BAN's Avatar
Q-BAN
LOL we must be using different search engines thanks!!!
First entry...
Old Feb 11, 2008 | 11:03 AM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
wing intructions
There was a very good step by step install of the wing in MC2 magazine a while back. It had informative pictures etc. Try their website, do a search. I'll bet this is exactly what you are looking for.
Old Feb 11, 2008 | 11:31 AM
Q-BAN's Avatar
Q-BAN
Yes, Ive heard. Do you remember witch isssue?
Old Feb 21, 2008 | 10:07 AM
charger's Avatar
charger
any tips on how to remove a JCW wing?
Old Feb 21, 2008 | 03:09 PM
bean's Avatar
bean
first question is, why?
i believe that it will be VERY difficult. i have thought about adding a CF boot, but i'm afraid that i won't be able to remove the JCW wing w/out damaging it. i'm not worried about the boot, since i would be replacing it, but it would totally **** me off if i damaged the wing. let me know how it goes.
greg
Old Feb 21, 2008 | 07:52 PM
batrugger's Avatar
batrugger
jc on the motoring underground removed his, but I don't know how. He sold it to me and it on my car now and looks great, so I know it can be done
Old Feb 22, 2008 | 06:52 AM
charger's Avatar
charger
I think that with a person slighlty pulling up.
Then a plastic scrapper to break the epoxy. Or a fishing line and saw through the epoxy.
Along with using a heat gun since it is cold outside. Or the cold might be better???
Old Feb 22, 2008 | 06:57 AM
Q-BAN's Avatar
Q-BAN
HoT Water, Lots of it.
Thats what my mechanic told me.
Old Feb 22, 2008 | 01:27 PM
bean's Avatar
bean
i build custom furniture and cabinetry for mega-yachts. i use epoxy on an almost daily basis. if the surfaces were properly prepared before gluing, one of two things can happen.....1. the sheet metal on the boot bends or 2. the weakest link in the construction of the wing is found.
Epoxy will laugh at a plastic scraper and fishing line. i don't think that heat will have much effect, either. i've used epoxy in many abusive situations and, if properly applied, doesn't fail. even if you want it to....
i would love to hear how jc removed his (as well as how he installed it)
keep me posted. i'm afraid of catastrophic failures.
greg
Old Feb 22, 2008 | 03:36 PM
charger's Avatar
charger
bean thanks for your insight. I've used epoxy compounds before and if used on a clean prepped surface they are as good a welded metals...
Hopefully the dealership didn't clean the surface or mixed the epoxy wrong.
Old Feb 22, 2008 | 04:21 PM
batrugger's Avatar
batrugger
The wing is installed with betalink. It is an actual OEM kit that you can get from the dealer which cures to a hard rubber. On the used wing, I had to scrape it out of the channel using a flathead screwdriver and then I installed using the OEM directions
Old Feb 25, 2008 | 04:01 PM
bean's Avatar
bean
thanks for the info. i used the same betalink product when i mounted my wing. i since loaned it to someone else and cannot check out the product. i was told that it was an epoxy, which would dry rock hard and not rubbery at all. i know that the wing hasn't come off at my MINI's terminal track velocity! it may be more similar to a catalyzed 3M 5200. i wouldn't want to have to take that off either! if i go with a cf boot, i won't really car what happens to the existing one, but i would hate to trash the wing.
greg
Old Oct 18, 2008 | 11:08 AM
SYZ MTRS's Avatar
SYZ MTRS
Hey all!
I just bought a JCW Wing and now cannot get the old wing off. What did you end up doing? I started with some dental floss once I got the bolts off and it didn't come right up.
I read this thread and it is exactly what others are running into.
How did you get your old wing off?
Mark
Old Oct 22, 2008 | 07:40 AM
Mike_MCS's Avatar
Mike_MCS
I got mine off my 03 MCS, undid bolts, lubbed it up with some WD40, then sawed with doubled up fishing line, used a plastic wedge aswell but it scuffed my paint work, have to try n polish out now, just be very gentle, it was stuck with adhesive pads so thats what you are cutting thru, go one side round the bolt then other.
minimofo
Factory JCW Talk (2009+)
130
Oct 14, 2016 06:14 AM
Indimanic
Mar 4, 2016 11:20 AM
sprp85
Aug 22, 2015 06:16 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
Indimanic
Aug 14, 2015 03:14 PM
