R50/53 Wheel Bearing - anyone changed it themself?
Old Feb 10, 2008 | 12:35 PM
scott_roberts's Avatar
scott_roberts
My wheel bearing has gone out, so I bought the part and I'm trying to do the work myself. Anyone here tried doing the repair on a wheel bearing on their Cooper S? By the way, it's a front wheel bearing.
Just wondering, 'cause I've tried to break the 1 1/4" nut loose that holds the hub/bearing on the axle and can't get it to budge. I'm using a pretty lengthy breaker bar to no avail.
Thanks in advance,
Scott
Old Feb 10, 2008 | 12:58 PM
mcs22004's Avatar
mcs22004
Thanks in advance,
Scott
Do you have a repair manual?
Old Feb 10, 2008 | 01:02 PM
Ryephile's Avatar
Ryephile
That front axle nut is torqued by the factory gorilla. Get yourself some PB Blaster and a big pipe!
Old Feb 10, 2008 | 01:27 PM
scott_roberts
What's PB Blaster? Where can I get that? Autozone?
You're the man, thanks!!!
Scott
Old Feb 10, 2008 | 01:30 PM
Ryephile's Avatar
Ryephile
PB Blaster is a much better formula than WD-40 for breaking bolts loose. You should be able to find it at most auto parts stores.
Old Feb 10, 2008 | 02:11 PM
scott_roberts
Just pickep it up at Autozone - uner $5. Thanks.
Now, to try it!
Old Feb 10, 2008 | 02:12 PM
scott_roberts
Oh, and I haven't picked up a repair manual. Thanks for the link.
Old Feb 10, 2008 | 07:16 PM
hemiheaded18's Avatar
hemiheaded18
Find a friend with a portable air compressor, a 1/2" drive impact gun and a big *** socket. Those 3 things will be a big help. Oh, and a torque wrench.
Old Feb 10, 2008 | 08:44 PM
scott_roberts
I finished the job.
I already had the 1 1/4" socket, but needed some power behind it . . . so I bought a 24" breaker bar . . . that and some PB Break (thanks above for the tip) did the trick.
That was the most difficult part . . . that nut is on there really tight. If you've ever done your own rotors, then the rest is cake.
Thanks for all the responses!
Scott
Old Apr 13, 2008 | 08:00 AM
ltz_mtr's Avatar
ltz_mtr
I just noticed my front driver wheel is beginning to roar and I need to replace my bearings- any tips from your install? What parts did you purchase?
Old Apr 13, 2008 | 11:28 AM
Ryephile's Avatar
Ryephile
You just need the hub/bearing itself, a new axle nut, and it would be nice to get 4 new bolts.
Old May 4, 2008 | 03:39 PM
Q-4000's Avatar
Q-4000
anyone have the torque specs for the axle nut and the bolts that hold the hub on?
Old May 4, 2008 | 05:54 PM
kapps's Avatar
kapps
182 Nm (134 lb ft) per Bentley Manual.
Old May 5, 2008 | 10:01 AM
SteveS's Avatar
SteveS
What were the symptoms which told you it was a bad wheel bearing?
Could you give brief step by step, and tips (if any) for the job?
I guess I should go to the library and see if they have a shop manual, but my lazy *** finds it is easier to sit here and type the question. Oops, did I actually type that?
Old May 5, 2008 | 05:28 PM
Q-4000's Avatar
Q-4000
is that for the axle nut or the bolts that hold the hub on?
Old May 5, 2008 | 06:18 PM
kapps's Avatar
kapps
Axle nut. It's the one that holds the half shaft to the hub. It's normally the highest torque load bolt on the car. My Europa needs 150 lb ft + and it still works its way loose.
Old May 5, 2008 | 06:35 PM
Ric in Richmond's Avatar
Ric in Richmond
I've always found a nice length of iron pipe from the hardware store does the trick.
Provides that little bit of extra leverage!! Just make sure you are turning it the right way!
Always use a craftsman breaker bar. That way when you snap it off you can get a new one.
Do minis have the peened spot on the nut like BMW uses? I haven't looked.
Old May 7, 2008 | 08:29 AM
Q-4000's Avatar
Q-4000
yea its bent in on its self a bit to hold it in place
Old May 24, 2008 | 04:54 AM
boater454's Avatar
boater454
Where is the best place to order a new bearing from?
Old May 24, 2008 | 05:01 AM
boater454's Avatar
boater454
"Could you give brief step by step, and tips (if any) for the job?"
I'm geting ready to start the job myself and would really appreciate this too. I'll do some more searching it may already be on here somewhere.
DixonL2
Apr 13, 2021 08:05 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
sabjcw
Aug 14, 2015 07:40 AM
