Rota slipstreams awesome (NOW WITH PICS)
Old Jul 18, 2003 | 04:25 PM
m3jstock's Avatar
m3jstock
I just got the last out of R-speed mounted on my car with 215/45/16 Azenis.
They look great.
I will get some pics when I can find my digital camera.
I will use these as track/autocross wheels and then use the 17 inch R90s on the street.
Bora
_________________
02 Cooper S
89 M3 JP Club Racer
Old Jul 18, 2003 | 04:34 PM
m3jstock's Avatar
m3jstock
35 lbs per corner based on my home scale.
>>They look great.
>>Bora
Old Jul 18, 2003 | 07:29 PM
norm03s's Avatar
norm03s
I just got the last set from the vendor I chose too. They are Rota Slipstream 16x7, 4x100, 45mm, 13.5lb., color =Gun-metallic w/polished lip and they are hub centric at 56.1 mm .
The "35 lbs per corner based on my home scale" must be the weight of your new wheel & tire combination? What size and weight did you have on before? How much weight did you lose per corner?
Old Jul 19, 2003 | 12:54 PM
red03miniS's Avatar
red03miniS
congrast
post some pics
they are good rims, been around a while for honda/acura applications
Old Jul 19, 2003 | 07:37 PM
m3jstock's Avatar
m3jstock
Answering a few questions at the same time:
1) The wheels that are on the car for daily driving are 17inch two piece R90s with Run Flats, I may end up selling these and getting a set of SSR comps, but I have not decided yet.
2) Here are the pics:
MCS Pictures Link
Old Jul 20, 2003 | 09:32 AM
norm03s's Avatar
norm03s
They do look great very clean. Thanks for the pictures.
Old Jul 20, 2003 | 08:40 PM
red03miniS's Avatar
red03miniS
very nice and clean car
Old Jul 21, 2003 | 02:02 PM
m3jstock's Avatar
m3jstock
Thank you, I try to take good care of the car
Old Jul 21, 2003 | 03:04 PM
Alex@tirerack's Avatar
Alex@tirerack
I figured we should display them
Alex
Old Jul 22, 2003 | 10:32 AM
norm03s's Avatar
norm03s
Did you use the stock wheel bolts and did the taper on the bolts appear to be the same as the Rota Slipstreams lug holes, 60 degree I think.
Old Jul 22, 2003 | 01:40 PM
m3jstock's Avatar
m3jstock
Yes
The stock wheel bolts work OK and they seem to be the same taper.
Old Jul 22, 2003 | 01:43 PM
m3jstock's Avatar
m3jstock
>>Alex
Thanks Alex,
I wished that the 17 inch SSR comps weren't so expensive.
Bora
Old Jul 22, 2003 | 01:48 PM
norm03s's Avatar
norm03s
Thanks for the reply, never assume anything is what I always say.
Did you happen to weigh you OEM S Lites and tires.
Old Jul 22, 2003 | 03:46 PM
m3jstock's Avatar
m3jstock
I never had S-lites, the car came with R90 17 inch wheels and they are HEAVY.
I will measure one when I get home, my guess is close to 50 lbs.
Old Aug 2, 2003 | 11:55 AM
norm03s's Avatar
norm03s
Just put my Rota Slipstreams 16x7 w/Yoko es100 tires on replaced OEM S lites w/all season Goodyear Eagle 205x45x17 tires.
On my scale OEM S lites and tires 45lb. ea.
Rota Slipstreams and tires 33lb. ea.
Saved 12lb per corner, total weight saved 48lb.
Old Aug 4, 2003 | 11:07 PM
Fonjozy's Avatar
Fonjozy
Thanks Bora and Alex,
Really looks great on Chilli Red
I just put these on my personal Mini since nobody wanted to buy them.
These sat on a wheel rack for over 2 month! without a single inquiry???
Their appearance changed drastically once I added rubber.
http://rspeed.net/mini/item.asp?dept...p;prod=405-502
http://rspeed.net/mini/item.asp?dept...p;prod=405-416
Joseph
R Speed Mini
Filmy
15
Jun 6, 2023 06:27 AM
Klenk
GP Talk
Sep 16, 2015 11:29 PM
minijoopers
Sep 9, 2015 03:36 PM
