R50/53 Question re: 36mm filter cannister socket
I need to purchase the 36mm socket to undo the filter cannister on my 2004 MCS. The sockets specifically intended for this purpose are 6 point. Sears sells a 36 mm socket, but its 12 point. Will it work? Ill-advised? TIA.
That said search eBay for 36mm socket and you'll have a bunch of very reasonably priced choices all ready short. Get one with a 3/8th rather than 1/2 drive as you'll probably find that easier to get in.
Rich
+1. Make sure you have a 1/2" drive ratchet to use with it...I haven't seen any 3/8's drive 36mm up at Sears.
It tends to be too tall with adapters unless you cut it down.:impatient Just give yourself plenty of extra time the first few times until you have the no leak loosen trick down pat and you should be good.
If you're referring to the socket...negative. Here in Baton Rouge, Autozone, Advance, O'Reilly, and Pep Boys only had the deepwell 36mm axle nut breaker.
I had to head to Sears and Sears alone. Neither Home Depot nor Lowe's had it either.
- Matt
- Matt
I had a 36mm socket from Sears that worked fine on my '06 MCS. It was too long (lack of clearance) on my wife's '05 MCSa. The automatic must shift the engine over about 1/2" to 3/4" to the passenger side compared to the stick. The socket wouldn't clear the plastic well once you started to loosen the cannister. I went to PepBoys and they had a short 36mm socket that worked great. Couldn't find a short 36mm at Sears.
On a R50 MC (02 to 06) any standard sized 36mm socket will work just fine. On the R53 MCS (03 to 06), you will need a 36mm shallow socket because there is less clearance behind the filter. I paid about $6-8 for mine at PepBoys. They sockets were shelved right next to the oil filter wrenches, not on the tool and socket isle.
I have the Sears 36mm and use it on my 04 MCS. There is not much room with a 1/2" drive, but it fits. I only use it for the first 1/4 turn and then do the rest by hand coming off.
Going back on it takes the socket to turn the filter down with the tight fit, but it is more of a process than needing to tighten the filter.
FWIT, it does not take anything more than hand tight for the filter because the seal is from the o-ring.
Kimolaoha
Jul 5, 2023 01:04 PM
polotska
Aug 23, 2015 09:10 AM
minipopkart
Aug 13, 2015 05:22 AM
