R50/53 fault code***gas line anti freeze
Old Jan 27, 2008 | 09:53 AM
redlinedave's Avatar
redlinedave
Has anyone got fault codes from gas line anti freeze
I put some in my wifes car and now her check engine light is on.
Just wondering if the gla caused the fault or if it is something else
Old Jan 27, 2008 | 10:08 AM
daemon2's Avatar
daemon2
Did you screw the gas gap back on tightly?
chpsk8's Avatar
chpsk8
You mean you put something like Heat, or STP Fuel Conditioner in, and now the CEL is on?
Should probably go have the code read, or go buy a reader (~$60 - worth every penny).
Your issues could be as simple as the gas cap not on right.
Where do you live? I live in the Midwest and the gas is already treated for freezing. (-15 here the other day). They still sell treatment products in the gas stations though even though it's not needed anymore.
Old Jan 27, 2008 | 10:14 AM
redlinedave
I was outside reading the code on her car
got 456....took off the gas cap put it back on went for a drive
after I cleared codes.Its all good for now.
Old Jan 27, 2008 | 10:16 AM
redlinedave
[quote=chpsk8;2004774]You mean you put something like Heat, or STP Fuel Conditioner in, and now the CEL is on?
Canadian Tire gas line anti freeze (methyl alcohol and stuff)
Old Jan 27, 2008 | 10:20 AM
redlinedave
I live in Ontario,I dont normaly use gla but we had a cold snap -12C and didnt want wifey stranded because the Cooper froze up.
Old Jan 27, 2008 | 11:36 AM
daemon2's Avatar
daemon2
As long as you keep good fuel in the car and the tank topped up in the winter you should not have a problem with a frozen gas line.
Moisture can collect in the tank when it is not full and there is a few heat cool cycles in the weather.
Anyway, I think it was just your gas cap. The GLA should not have caused a problem.
p0456 is: evaporative emission control systm leak detected - minor leak
Old Jan 27, 2008 | 11:39 AM
redlinedave
went for a good run no codes
Old Jan 29, 2008 | 08:45 AM
Flick's Avatar
Flick
-40C here in Edmonton today...no gas line antifreeze...Mini fired right up this morning...of course, it was plugged in overnight!
conky
Apr 6, 2016 08:03 PM
PSU 98
Sep 11, 2015 11:20 AM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
