R56 Windshield Defost?
Old Jan 24, 2008 | 09:54 PM
TBall's Avatar
TBall
Windshield Defost?
I've noticed that when I press the defrost button for the windshield, it automatically turns the fan on HI -- If I try to adjust the fan speed down OR click on the controls for other vents (floor, front, etc), it turns off the defrost.
Is this a malfunction? Does the defrost only operate by itself and in high fan speed?
Just curious.
Old Jan 24, 2008 | 10:03 PM
funkdaddy's Avatar
funkdaddy
My BMW worked the same way - I don't have my Mini yet, but I assume that's how it works, if you want it lower, you have to do it manually.
Old Jan 24, 2008 | 10:24 PM
TBall's Avatar
TBall
The problem is, if I try to lower it (i.e. the fan) it shuts off the defrost. So, I guess it only operates in high fan speed?
Old Jan 25, 2008 | 12:29 AM
Modnar's Avatar
Modnar
All the defrost button does is set it to full fan speed, all air flow to the windshield, and full hot. If you want to do the same thing, but with a lower fan speed just set your air flow control to only direct up, and set the heat to high. Then adjust the fan to your liking.
On my BMW hitting the defrost button was sometimes the only way into tricking the auto AC into giving you properly hot air.
Old Jan 25, 2008 | 01:15 AM
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
Good reasons to avoid the Automatic HVAC controlls...
Old Jan 25, 2008 | 02:36 AM
DOT191's Avatar
DOT191
If you push the defrost button & hold it for for a few seconds you then can adjust the fan speed to any level you want.
2003 MCA, PW/BLK, CVT, Premium Pkg, Spoiler. Bought New. Has been a Great , trouble free car. Ours has the Auto HVAC. No problems.
Old Jan 25, 2008 | 02:39 AM
glangford's Avatar
glangford
I concur. I have a 2004 accord EX-L, I wish it didn't have auto AC and dual climate zones.
Old Jan 25, 2008 | 05:05 AM
rhawth99's Avatar
rhawth99
Instead of using the auto defrost button on the upper left, use the button on the right that has the symbol that points up. This will send air to the defrost vents and you have full control over the fan speed. The auto AC is a pita. BTW, holding the button for a few seconds as suggested above does not work for the '05 and '06 MCS.
Old Aug 31, 2010 | 06:13 AM
Hutchinson's Avatar
Hutchinson
Possible windshield defrost problem
Just bought my Mini in Spring and noticed that when I recently put the windshield defrost on that it didn't put out the usual blast of hot air that you normally expect but the fan speed did go to high.
Is this normal?
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
bahman
Feb 14, 2016 10:29 AM
aldito2
Sep 30, 2015 10:44 AM
bahman
Sep 26, 2015 07:38 PM
The Rossness
Sep 17, 2015 03:06 PM
