Hub ring help
Hub ring help
Hello.
I found a set of Enkei NT03-M wheels.
I know that I will ned Hub Rings and would like to track down now ...
How can I confirm the wheel bore / hub size ?
I know the MINI is 56.1 mm
The rings that I can find are 73.1 or 72.62
Any help ???
these wheels >>
Finish Shown: Hyper Black
THANKS
Any help ???
these wheels >>
THANKS
What size are they? Looks like they should be 72.6 bore dia.
Your vendor always can provide the information you need and usually the centering rings as well.
see
http://www.edgeracing.com/wheels/enkei_wheel/
17x7.5 $169 each NT03 M Hyperblack
Check with Leo at Edgeracing.
If you already have the rims then take them to a good aftermarket tire and wheel shop and they can measure the size of the rings.
Then order the right ones.
see
http://www.1010tires.com/hubrings.asp
MINI hub bore is 56.1 mm
1010tires will assist if you give them the wheel information.
see
see
Yes 72.6
Now I can order or at least have a educated discussion at the wheel store
72.6 is the correct hub diameter of the NT03+M. We have plastic or aluminuim rings available.
Leo Barrios
leo@edgeracing.com
800-489-5353 x211
NT03+M Sale: https://www.northamericanmotoring.co...d.php?t=125822
Leo Barrios
leo@edgeracing.com
800-489-5353 x211
vulkandino
Oct 31, 2015 08:29 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
Nicefeet
Sep 24, 2015 06:53 PM
