R50/53 Anything special about alignment on the MINI
I hit a pothole and destroyed a tire. I want to get the alignment checked and adjusted if necessary (its now has a ever so slight pull to the right) Is the standard alignment on the Mini just like any other vehicle or do I need to find a shop that knows about the mini.
My towers have always shown a very slight tower mushroom. You can tell that the bolts are not perfectly straight up in down in relation to each other any more. The car never had any adverse effects and drove just fine. After the pothole the towers look the exact same as before.
Should I jack the car up and hammer the towers flat with a block of wood and hammer before an alignment? I have driven the past 30,000 miles with the little bit of mushroom that currently is their with no adverse effects at all...
If it gets aligned before hammering down the tower will that change the alignment?
andrewjg1994
Jan 29, 2021 07:45 PM
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
bctf1
Aug 6, 2015 12:55 PM
tippin
Aug 5, 2015 08:43 AM
