Suspension Suspension Install - Time and Cost
Old Jan 20, 2008 | 01:58 PM
mkell's Avatar
mkell
I am wondering how long it would take a professional shop to install 1) springs or 2) coilovers. I am debating which way to go and am curious to see what the labor differences will be.
Also, if you have had either done, how much did you pay?
TIA.
Old Jan 20, 2008 | 02:49 PM
RedSkunk's Avatar
RedSkunk
I can't imagine a shop would charge significantly more for one or the other, since it involves the same exact process. Springs MIGHT take marginally more time since you're breaking down the old struts, but then again many coilover units re-use the stock top hats, so...
Old Jan 20, 2008 | 05:04 PM
etalj's Avatar
etalj
I'm getting coilovers installed, corner-weighted, lowered 32mm, and a four wheel alignment for roughly US$400-430
Old Jan 20, 2008 | 05:39 PM
rjtrout2000's Avatar
rjtrout2000
Springs will cost a bit to install but much less to purchase. Is the car daily driven, or is it a track car?
Old Jan 20, 2008 | 05:43 PM
mkell's Avatar
mkell
Daily driven car. I know I don't *need* coilovers, but the height adjustability would be nice. If not, I will probably go with the M7 springs. Also, I could get H&R coilovers for around $700.
Old Jan 20, 2008 | 09:01 PM
RedSkunk's Avatar
RedSkunk
Corner-weighting and alignment will add onto the price of course. If you're corner-weighting your coilovers, which I doubt many people do on their street cars.
Old Jan 21, 2008 | 03:33 AM
etalj's Avatar
etalj
if you don't corner balance a car with coilovers, the system won't work as well as it can
Old Jan 21, 2008 | 02:31 PM
Silkworm's Avatar
Silkworm
On corner balance subj, I notice with my tools and parts for copier repair in the boot (50-75lbs) I get less rotation than when I take the junk out. So with that said im going to corner balance for when the stuffs out and I have half a tank of gas. Half a tank so im closer to the middle of the weight diff as I use up gas.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
