Suspension Powerflex Bushings Help!!!!
Old Jan 19, 2008 | 12:22 PM
kenros's Avatar
kenros
Hi, I bought the front control arm bushings and rear trailing arm bushings for my '05 MC, I want to know in anyone have pics of the installation process, I tried to install the rear ones but I don't know how to fit them.
The parts that outmotoring sent me are:
Front PFF5-101
Rear PFR5-110
I will appreciate your help, the sound of the stock front bushings is killing me!!
Old Jan 19, 2008 | 09:31 PM
rjtrout2000's Avatar
rjtrout2000
the sounds from the powerflex are gonna be so much worse than OEM.
Old Jan 20, 2008 | 07:28 AM
meb's Avatar
meb
Do not use anything but a stock bushing in the rear!!! Replace it with a stock unit if it is worn!
Old Jan 20, 2008 | 08:11 AM
meb's Avatar
meb
Old Jan 20, 2008 | 10:30 AM
cristo's Avatar
cristo
Alliance Member
The rear bushing PFR5-110 is actually an insert to firm up the oem rubber
trailing arm bushing for early MINIs ... up to 03/2003?
There's also a PFR5-1102 that is for later 1st Gen MINIs. You might need
that one if you're gonna put one in despite meb's warnings.
Here's an older thread about the rear bushing inserts.
https://www.northamericanmotoring.co...ad.php?t=68901
Old Jan 20, 2008 | 06:40 PM
kenros's Avatar
kenros
So I will contact Outmotoring becuase they sent me the wrong bushings. But about the front control arm bushings, thay are noisy too?? I think that the OEM bushing will broke again quickly, my MC have only 45k miles and the front bushing are too damaged. I will appreciate if someone with them installed can give me his feedbak. Thanks for the help.
Old Jan 20, 2008 | 07:05 PM
IanF's Avatar
IanF
The front bushing installation is a bit involved. I will likely be doing this job soon, so I've been doing some research. A search dug up this page:
http://www.greenwayeng.com/wsmod/cooper/
...which looks pretty good for the DIY wrench...
This is another thread where the installation is done with the BMW/MINI bushing removal tool:
https://www.northamericanmotoring.co...ad.php?t=63869
Old Jan 21, 2008 | 03:18 AM
kenros's Avatar
kenros
Thanks very useful!!!!
Old Jan 21, 2008 | 10:23 AM
meb's Avatar
meb
Allow 4-6 hours for the front LCA bushing replacement.
Old Jan 21, 2008 | 11:50 AM
k-huevo's Avatar
k-huevo
Here's another approach https://www.northamericanmotoring.co...ad.php?t=99725
Old Jan 21, 2008 | 01:28 PM
kenros's Avatar
kenros
Originally Posted by k-huevo
Old Jan 23, 2008 | 04:27 AM
kenros's Avatar
kenros
Did someone know the diameter of the stock bushing, I want to make the tool described above
Old Jan 23, 2008 | 05:36 AM
IanF's Avatar
IanF
I need this myself, so I hope to take a measurement this weekend.
Old Jan 23, 2008 | 06:28 AM
GT4RACER's Avatar
GT4RACER
you don't need a speciality tool for the front bushings. I used a cut-off wheel to carefully slice the old bushing and pry apart, slip off the old, lube slide on the new. press the collar back on, reinstall the a-arm. take the arm off the car it is easier to deal with. everything I needed can be found at any parts house. except for the press. took about 6 hours.
Old Jan 23, 2008 | 07:32 AM
IanF's Avatar
IanF
Umm... how did you get a cut off wheel in there?
Old Jan 28, 2008 | 05:54 PM
kenros's Avatar
kenros
Rattle continues!!!!
Finally I installed the front bushings (what a pain!!!) but the rattles on the front right side continues, I verified the ball joints (2) and the strut and the are good.
What else can be????
Also outmotoring send me the bushings PFR5-1102, because first time they sent me the PFR5-110 (yellows)and they are for a 02 mini and I have an 05 MC. But why powerflex website says that the small ones (violet PFR5-1102)are for the 02 Minis????
Please tell me how to install the rear ones I have no idea how to do it. Pictures could be better!!!
YaTuSabe
Aug 23, 2018 11:41 AM
bahman
Feb 14, 2016 10:29 AM
Mrbrown
Suspension
11
Dec 31, 2015 09:31 AM
pahg
Oct 5, 2015 11:50 AM
rt808
Sep 29, 2015 03:15 PM
