Different tires front and rear
Old Jan 15, 2008 | 12:56 PM
mcsmike's Avatar
mcsmike
Is there any problems when running different tires front and rear? Im just about ready to buy the Goodyear Eagle F1 GS-D3 in 215-45-17 and leave the rears with the stock runflats till they wear out. I dont do much agressive driving in the form of curve killing. Opinions needed!!!
Mike
Old Jan 15, 2008 | 01:08 PM
Eric_Rowland's Avatar
Eric_Rowland
Not adviseable. They'll handle differently, thus change the characteristics of the car that you'be gotten used to.
Note that the goodyears should be much stickier, so you may experience oversteer as the rear tires lose traction earlier.
If you were going to go that route, I'd put the runflats on the front, as the fronts tend to wear out MUCH (3x?) faster than the rears. That way you'll spend as little time as possible on two different types of tires and minimize the oversteer risk.
Otherwise, you may wear out the new ones before you wear out the runflats!
Old Jan 16, 2008 | 03:14 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Mike
Replace all four with non runflats is your best option. If needed you can remove the good runflats and keep them to sell as a pair to another owner that prefers runflats and gets one or two damaged. Non runflats are quite a bit less expensive than runflats.
Old Jan 16, 2008 | 03:23 PM
MINIAC's Avatar
MINIAC
When buying two new tires, they should be mounted on the rear:
Mixing runflat and standard tires is NOT recommended:
W0TM8
Dec 19, 2019 07:50 AM
emulajavi
Dec 24, 2018 09:15 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
Minibeagle
Aug 13, 2015 10:00 AM
