R56 Alignment
Old Jan 9, 2008 | 07:48 AM
mattminicoop's Avatar
mattminicoop
Alignment
Anyone else having issues with their alignment?
I purchased my MCS in early July 07 and by September the alignemnt was out. I had it corrected in November, the dealership paid half for me - it only cost $90 anyway However, it seems to be out again already - both times pulling slightly to the left. Is it me, is it the car or these damn PA roads?
Old Jan 9, 2008 | 08:03 AM
ianparcher's Avatar
ianparcher
Check the tire PSI first if you haven't yet. If there is still a pull try rotating the tires front to back. See if that helps with the issue.
Old Jan 9, 2008 | 10:24 AM
mattminicoop
Dumb question time... is that something I could just do myself with the jack? And do you mean literally switch Front Left with Rear Left and Front Right with Rear Right?
Old Jan 9, 2008 | 10:33 AM
ianparcher's Avatar
ianparcher
Yep I mean just that..front to back on the same side. If there's a tire making the car pull this should fix it. As for a jack, when I did this I used a floor jack. The car is stiff enough to lift the whole side by the rear jack point. I haven't seen the stock jack so I don't know if I would trust it. If you have a friend that is even a little DIY this should be easy as pie.
Old Jan 9, 2008 | 03:14 PM
dreman's Avatar
dreman
Mine pulls to the left as well... also took delivery in July and have about 12k miles on it. I didn't think this was normal
Old Jan 9, 2008 | 04:04 PM
r56mini's Avatar
r56mini
Mine was delivered on 7/10/07 and it's been driving straight.
Old Jan 9, 2008 | 04:26 PM
dreman's Avatar
dreman
Would hitting nasty pot-holes on the interstate affect alignment?
Old Jan 10, 2008 | 05:19 AM
Nightsky's Avatar
Nightsky
It certainly could.
Old Feb 7, 2008 | 03:13 PM
Mini4ten's Avatar
Mini4ten
I had my alignment done today.. I did feel it pulling, but realized I needed it done because my front tires were wearing unevenly on the sides. $380 later...I was told the alignment is $230 and I should also rotate my tires and BALANCE them for $150. Am I getting ripped or what?
BTW-I got my car April 2007 and have 8700 miles on it.
I don't want my tires to wear down since they're over $400+ each!
Hope I'm doing the right thing..
Old Feb 8, 2008 | 04:47 AM
glangford's Avatar
glangford
380 for alignment?? I haven't done mine yet, still straight as an arrow, but I always get my alignments at sears, 4 wheel alignment is about 60 bucks, balance and rotate 30. I was talking to my honda dealer and mentioned that I had the alignment done at sears and he said they do good work. Any tire place will do fine. Get the specs for alignment, they are posted here somewhere some place do not have them yet. You don't have to go to the mini dealer for that, not at those prices.
Old Feb 8, 2008 | 08:43 AM
mattminicoop
As I said at the top, I paid $90 for mine at the dealer.....but they split the cost with me, so I guess the regular price is around $180.
Old Feb 8, 2008 | 09:33 AM
PistWalrus's Avatar
PistWalrus
Hopefully its just a tire. A tire can get what is called radial pull which will make the car pull to one side just like it would if it was out of alignment. If you swap the tires front to back and it goes away then you have a bad tire. Tire manufactures usually will warranty a tire if it has radial pull. Radial pull comes from a manufacturing defect (5 years of putting tires on during college).
Old Feb 8, 2008 | 09:57 AM
emtrey's Avatar
emtrey
my car was fine as delivered ( or so I thought--no pulling--no unusual tire wear)
Last month a pothole destroyed a wheel and tire so it had to be-realigned.
Infinitely better tracking with the hand done alignment. Tracks straght and true and centers out of turns much better.
Not cheap, but insurance paid 1/2 the bill. 2 hours labor to mount and balance the tire and align car ( he did rotate the tires as part of the deal) $280.
Old Feb 8, 2008 | 10:45 AM
Robin Casady's Avatar
Robin Casady
I had my wheels balanced and alignment check and adjusted at a couple independent tire places. It didn't cost anything like what you guys are paying to dealers. Neither place had the R56 specs. So, I had to provide them. A dealer was kind enough to send them to me.
Old Feb 8, 2008 | 11:18 AM
Diploman's Avatar
Diploman
Useful info which I have filed. Thanks, Robin.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Keet
Suspension
Aug 30, 2016 03:46 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
daviday
Sep 25, 2015 01:31 AM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
