R50/53 My boost gauge needle bounces
Old Jan 7, 2008 | 05:25 AM
grillhands's Avatar
grillhands
Is this a symptom of belt slippage? It bounces from 14-16psi. I got 36k on my 03 with original belt. Do you think it's time to change.
Old Jan 7, 2008 | 07:49 PM
grillhands's Avatar
grillhands
Wow, i'm the only one on NAM that has this problem! I feel special
Old Jan 7, 2008 | 07:52 PM
jeffc's Avatar
jeffc
7th Gear
Not sure if thats your issue but yeah not a bad idea to change the belt.
Old Jan 7, 2008 | 07:59 PM
mmatarella's Avatar
mmatarella
I'd get a handheld 'regular' cheap vacum boost troubleshooting gauge and hook that baby up to make sure it does the same thing first. You might have better luck getting hits if you post in the Stock problems or the 'mods drivetrain' forum. More likely to get tech minded folks cruising those forums.
Good luck!
Old Jan 8, 2008 | 05:07 AM
grillhands's Avatar
grillhands
Good luck!
I thought i should put it there, but i don't know why i choose this forum. This problem just started to happen a few days before.
Old Jan 8, 2008 | 05:12 AM
MiniStupidfun's Avatar
MiniStupidfun
Vibration.....
Old Jan 8, 2008 | 09:25 AM
grillhands's Avatar
grillhands
Only at high rpms it starts to bounce. I have an autometer gauge.
Old Jan 8, 2008 | 09:30 AM
ImagoX's Avatar
ImagoX
Did you check the hose? You might be kinking someplace. LOTS cheaper to start there, then move to replacing belts when you're 100% sure the hard line's not constricted someplace. Depending on where you lashed it, it might be torquing or bending at high RPMs when engine components flex and move...
Old Jan 8, 2008 | 09:35 AM
grillhands's Avatar
grillhands
I'll check everything again today. Maybe it's the loose nut behind the wheel!
Old Jan 8, 2008 | 09:44 AM
Dr Obnxs's Avatar
Dr Obnxs
Also..
make sure the hose connection are tight. For my VGS, I used wire-ties to keep the cheap hoses I used from expanding and burping. Once you are sure that all the connections are tight (including IC couplers), then confirm with another guage. Belt slippage, and the by-pass valve could both be sources. If it's not any of those, finding the sucker could be harder still. There are shops that can pressurize your intake track and look for cracks, leaks and bad seals.... Let your fingers do the walking...
Matt
Old Jan 8, 2008 | 10:02 AM
grillhands's Avatar
grillhands
Matt
The oracle has spoken...Meaning i've seen you alot on here and you definitly now your sh$t. I will check it all out when i got home from work. Thanks guys.
Old Jan 8, 2008 | 10:09 AM
Dr Obnxs's Avatar
Dr Obnxs
No oracle here...
just a car guy who's owned one for a while. And has spent way too many hours here reading....
Matt
now, k-huevo might deserve the name!
Old Jan 8, 2008 | 06:02 PM
ozarkroots's Avatar
ozarkroots
Coordinator :: Mini's of the Ozark Region
Bouncing Boost
I have a boost meter and it does not bounce at 14 to 15 # boost which is the first tip that you have a reduction pully ...right?
The first place I would look is the belt as 36000 miles is just about all it is good for with that pulley, or possibly the tensioner is getting weak and bouncing at that RPM. Randy Webb installed my pulley and the last thing he said was to replace the belt after about 32000. I also have a 2% crank pulley which just adds to the problem. Good luck but I would do some careful checking before things come unglued.
Old Jan 8, 2008 | 06:08 PM
jeffc's Avatar
jeffc
7th Gear
My bounces and I have a Autolite as well.
Doc Pain
Oct 28, 2015 07:09 PM
papawhiskey
Sep 30, 2015 02:50 PM
jennster
Sep 28, 2015 06:19 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
