16 tires size
Old Jan 4, 2008 | 09:06 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
16 tires size
I just ordered a set of 16x7 spun supermesh........what is the best size i should get for auto-x and street? Im also looking for a good tire thats sticky..im torn between the Hankook RS2 or falken zenis 615...any suggestions?
Old Jan 4, 2008 | 01:54 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Both those tires are fine and relatively well priced.
What is your suspension setup?
What class of autocross would you compete in? Extreme Performance tires are worth a look. 24.9" tire diameter is taller than stock and OK for stock suspension but a bit too tall for lowered MINIs.
You can run Max performance Summer tires on the street if your weather is mild. Cold is not good for those tires and they generally wear out (200 treadwear likely).
Consider Extreme Performance Summer tire-
Bridgestone Potenza RE-01R 140 treadwear
205/45-16 $151 each fits rims 6.5-7.5" wide, 23.2" tire diameter 21 lbs
205/55-16 $109 each fits rims 5.5-7.5" wide, 24.9" tire diameter 26 lbs
225/50-16 $117 each fits rims 6-8" wide, 24.9" tire diameter 27 lbs
Better performance wet or dry, faster wearing.
Another possible tire to consider is BF Goodrich g-Force KDW-2
300 treadwear Ultra High Performance Summer tire.
205/40-16 $125 each fits rims 7-8" wide, 22.4" tire diameter
205/45-16 $127 each fits rims 6.5-7.5" wide, 23.1" tire diameter
205/50-16 $119 each fits rims 5.5-7.5" wide, 24.1" tire diameter
215/40-16 $136 each fits rims 7-8.5" wide, 23.0" tire diameter
225/45-16 $143 each fits rims 7-8.5" wide, 23.7" tire diameter
Also see in UHP tires
http://www.tirerack.com/tires/survey...ireSearch=true
Old Jan 5, 2008 | 10:48 AM
littlehandegan
What about a 215-45-16? im going to be on m7 springs
Old Jan 5, 2008 | 11:13 AM
minihune's Avatar
minihune
M7 Springs will give you a drop so smaller than stock tire diameter and 215mm tires would work.
215/45-16 doesn't give any Extreme Performance or Max Performance tires at tirerack.com
That size fits rims 7-8" wide 23.6" tire diameter.
That size shows very limited tires in UHP summer class:
Dunlop Direzza DZ101 $127 each 300 treadwear 21 lbs
Bridgestone Potenza RE010 $169 right or left, 120 treadwear 22 lbs
Yokohama A022H0 $238 each closeout (Honda left) 120 treadwear 21 lbs
Edgeracing.com shows-
Both Max Performance Summer tires rated 200 treadwear
Falken Azenis Rt615 $89 each 21.7 lbs
Hankook RS2 Z212 $90 each 20.5 lbs
Old Jan 5, 2008 | 03:21 PM
90STX's Avatar
90STX
215/45-16 Azenis work really well as a combo street/auto-x 9 month tire. I've gone through one set of the 615 Azenis, and 7 sets of the original 215 model Azenis on the MCS, all in that size. The Hankooks may be better for street/track day use, by some reports.
The new Bridgestone RE01-R is an even better street/auto-x tire (maybe the best you can buy right now), but the 16" sizes aren't great for a MINI. Either really short, or too tall.
Scott
90SM
Old Jan 7, 2008 | 02:43 PM
leo@edgeracing.com's Avatar
leo@edgeracing.com
We ran 15" wheels on the Mini for autoX event to test the Falken 615 and Hankook Rs2. The Rs2 gave the best times on the course so I would suggest those over the RT615's. The tire size we ran was 205/50R15. Let me know if you have any questions.
Leo Barrios
leo@edgeracing.com
800-489-5353 x211
http://www.edgeracing.com
Old Jan 7, 2008 | 06:58 PM
littlehandegan
Leo Barrios
leo@edgeracing.com
800-489-5353 x211
Thanks....i ordered from yall...this will be my third set of tire from you guys!!!
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
Waszak
Oct 21, 2017 05:55 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
