R50/53 2006 S antenna base issue
Old Jan 3, 2008 | 12:00 PM
ashti24's Avatar
ashti24
I broke my antenna base going through a car wash. I have a 2006 mini cooper s. The dealer is asking a high price to fix it, and the part costs about $50. Does anyone know where to locate instructions on how to repair the part online?
Old Jan 3, 2008 | 01:13 PM
capnmini's Avatar
capnmini
you could just replace it with a nicer looking stubby antenna from any of the vendors!
Old Jan 3, 2008 | 01:26 PM
slickfast's Avatar
slickfast
Not if the antenna base is broken... do a search, someone posted about this very issue a while ago
Old Jan 3, 2008 | 02:23 PM
Dave.O's Avatar
Dave.O
Car wash?
tisk tisk tisk
sorry man that why I always hand wash. Yeah its 23 degrees around Philly today but the car is worth it. Plus all you just need a pair of rubber gloves because cold water is not that cold if you dont put your hand in it with gloves on. (Try it ) I bet it $50.00 + a car wash cheaper.
Old Jan 3, 2008 | 02:28 PM
Dave.O's Avatar
Dave.O
Spoon feed time...
Try google " 2006 Mini Cooper Antenna Base"
StubbyAntenna Base
Black
- compatible with the following antennas: A, B, G, H, I, J, O, X, Y, Z-series
- Color: Black
- non-functioning $9.99USD StubbyAntenna Base
Angle Adjustable
- Color: Black, Silver
Old Jan 3, 2008 | 03:34 PM
Gromit801's Avatar
Gromit801
Lesson learned. NEVER use an automatic car wash.
BTW, Welcome to NAM!
Old Jan 3, 2008 | 05:18 PM
lotsie's Avatar
lotsie
Originally Posted by Chili_Mini_PA
Spoon feed time...
I think just giving the link is good enough, no need to be rude first
Mark
Old Jan 4, 2008 | 05:51 AM
slickfast's Avatar
slickfast
Spoon feed time...
StubbyAntenna Base
Black
- Color: Black
Angle Adjustable
Neither of these actually work...? I think OEM antenna bases are only around 50 bucks, no need for a fakey!
Old Jan 4, 2008 | 06:14 AM
lilruffcat's Avatar
lilruffcat
Actually how I do it is I pop the headliner down at the back of the car. The cover on the roof actually popes off and you use a 19mm wrench to take the nut off. Then the whole antenna base will come loose and you can disconnect the wires and pull it out. Then reverse for install. Sometimes you have to reglue the clips to the headliner, but no big thing. So all you'll really need is the base and a new antenna.
I found this on the other thread.. here is the link so you can go surf through it at your leisure.. this thread has some good info.. good luck!
https://www.northamericanmotoring.co....php?p=1904919
W0TM8
Dec 19, 2019 07:50 AM
blackie
Aug 23, 2015 08:44 PM
bugeye1031
Aug 15, 2015 08:14 AM
Dashdog
Aug 10, 2015 06:17 AM
