Navigation & Audio Auxiliary Input
Old Dec 30, 2007 | 12:43 PM
stevenratner's Avatar
stevenratner
Auxiliary Input
Does the Cooper S radio come w/ an auxiliary input for an ipod or other MP3 player?
Also, what does it mean the radio is pre-wired for sirius?
Old Dec 30, 2007 | 12:50 PM
ImagoX's Avatar
ImagoX
Depends on the year and model. I know the upgraded HK stereo on the later models has an AUX plug available from MINI or places like Outmotoring, but I BELIEVE that the older models and the basic head unit on the Cooper does NOT. You can always replace the head unit however, with one that has an external AUX input.
Not sure what that means about pre-wired for Sirius - I just used the FM transmitter on my Sirius receiver and it sounds great - my AUX input is still clear to use with my iRiver MP3 player that way.
Old Dec 30, 2007 | 02:23 PM
MiniDaMoocher's Avatar
MiniDaMoocher
My 08 Cabrio with stock radio came with an AUX input in the glove box.
Old Dec 30, 2007 | 02:33 PM
ImagoX's Avatar
ImagoX
The 2008 is a SECOND GENERATION MINI - he posted in 1st Gen, so the assumption is that it's a 2006 or earlier. Good to know that MINI bought a clue and put the AUX input in as a standard item in the 2nd Gen model though...
Yucca Patrol's Avatar
Yucca Patrol
The standard aux input only costs about $40 and is a very easy DIY project. I'd avoid the much more expensive iPod interface and just go with the aux inmput.
Old Dec 30, 2007 | 04:18 PM
MiniDaMoocher
The 07 & beyond tin tops are 2nd generation, but the 08 Cabrio is still 1st. It will be changing in 09. It is nice that they added the AUX port, though they put it in a crappy spot in the glove box. Oh well, can't have everything...
Old Dec 30, 2007 | 04:47 PM
Guinness76's Avatar
Guinness76
Yeah, how are you supposed to skip to the next song when your mp3 player is in the glove box? I never figured out the logic behind that.
Old Dec 30, 2007 | 06:32 PM
ImagoX's Avatar
ImagoX
Why not just use a $6 stereo cable and keep the player itself in the center console? You should be able to close the glove box lid with the cable protruding - I do it with my Garmin GPS power cable, which is permanently wired and stored in the glove box.
Old Dec 30, 2007 | 08:07 PM
MiniDaMoocher
Short trips I'm fine with my MP3 CD's. Long trips, I'll throw the ipod on a dock, probably with the cable like you suggest. Eventually I hope to go with a Dice unit, though I still have a bunch of questions about it. Way down on the mod priority list though.
Old Dec 30, 2007 | 09:05 PM
Eric_Rowland's Avatar
Eric_Rowland
That, or you just unscrew the Aux in from the glovebox, and thread that cable whereever you want to plug in your Aux in...
Old Jan 6, 2008 | 05:03 PM
Mini-RI's Avatar
Mini-RI
I'm curious - why avoid the iPod interface and go with the aux input?
What are the pro's and con's of each?
Old Jan 6, 2008 | 11:01 PM
Eric_Rowland
OEM ipod
Pro - recharges ipod, control by MFSW
Con - MINI specific playlists (MINI1 - MINI5, MINI6 is all)
Aux-in
Pro - control w/ipod, any 3.5mm plug for aux in
Con - control w/ipod , no recharging (I use a Belkin dock)
Old Jan 6, 2008 | 11:23 PM
tennis_man's Avatar
tennis_man
With the aux input I use a Belkin Dock Connector. It recharges the Ipod plus it does not use the earphone jack for the audio out so atenuation is not affected.
Old Jan 7, 2008 | 10:29 AM
Toro71's Avatar
Toro71
I have the 2003 with Harmon Kardon upgrade, is there a jack that I can simply plug my ipod into? I wan a low cost solution here.
Old Jan 7, 2008 | 02:06 PM
MaxMini81's Avatar
MaxMini81
Wanderer
HK Drive+Play
I use the AUX input in tandem with a Harmon Kardon Drive + Play. All together it was about $80 when i got it. The drive+play has a display screen and seperate remote module. Im a big fan and theres lot of information on the forums about this particular device. It also charges the iPod.
Old Jan 7, 2008 | 05:01 PM
Mini-RI's Avatar
Mini-RI
Originally Posted by Eric_Rowland
OEM ipod
Aux-in
Thanks for the succinct reply. One follow-up on the OEM? The playlist issue - do you actually have to create playlists named MINI1, etc? Or can you just let it play songs randomly from the library with no playlist?
Old Jan 8, 2008 | 12:04 AM
Eric_Rowland
Don't know first hand, but here's a post from someone who apparently knows.
So according to this button 6 will play all your ipod songs.
Originally Posted by findude
FWIW, I have the MINI, dealer-installed iPod adaptor, and it works fine but is indeed limited. You have to make playlists named MINI1, MINI2, MINI3, MINI4, and MINI5. These numbers correspond the the first 5 buttons on your radio (I have the H/K). Button 6 is reserved for simply playing everything on the iPod.
With the MFSW you can go back and forth from track to track using the arrow buttons. If your MINI playlists are long, then this can take a while, so in practice we have found that we create short playlists and typically keep them to a single album or musician. We rarely drive more than 45 minutes at a time, so this works well and replaces the functionality of a CD changer. For longer drives, we'd probably make longer playlists.
One disappointment is that the head unit display simply says TRACK 05 (or whatever number) and does not identify the name of the artist, album, or song as the iPod does, and as the radio does for stations that broadcast that information. When I had it installed, the SA at the dealer warned me that some iPods (or head units?) will display the information and others won't, and that there was no guarantee mine would or would not. Perhaps this is the upgrade anticipated for the rumored early 2006 release of the next generation iPod adaptor...
NYMADMINI
Dec 14, 2016 02:33 PM
eliseo1981
Nov 2, 2015 11:24 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
BossyR56
Sep 28, 2015 11:33 AM
Ntety
Sep 2, 2015 08:39 PM
