R50/53 Strange sound when braking
Old Dec 28, 2007 | 11:11 AM
DrWhoMini's Avatar
DrWhoMini
Hi gang,
Whenever I apply pressure to the brakes, I get a strange sound. It sounds like when you first brake after the car has been sitting out in the rain and the rotors are wet. Although this happens WHENEVER I brake.
The brakes work fine, the noise is just very noticeable.
Is this normal? Indicative of a greater problem?
Old Dec 28, 2007 | 12:02 PM
kenchan's Avatar
kenchan
i would definitely check the pads and any unusal grooves in the disc.
Old Dec 28, 2007 | 12:11 PM
OctaneGuy's Avatar
OctaneGuy
How many miles are your current brake pads? How many pad changes have you done so far? Have you ever changed the rotors? Maybe it's the brake sensor that's wearing through.
Originally Posted by DrWhoMini
Hi gang,
Old Dec 28, 2007 | 04:13 PM
DrWhoMini's Avatar
DrWhoMini
Just did a visual and the rotors/pads look fine.
I checked the service records and the car had its brakes changed in February.
Old Dec 28, 2007 | 08:05 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Brakes that look fine should not sound like that. I'd try some brake rotor cleaner on them.
Old Dec 30, 2007 | 08:12 PM
wildcrazy442000's Avatar
wildcrazy442000
Are you still in the 3 year, 36,000 free maintenance range? If so let the dealer deal with it.
Old Dec 31, 2007 | 09:58 AM
DrWhoMini's Avatar
DrWhoMini
Yes, what I plan to do. The closest dealer is 96 miles away which makes servicing a pain.
I noticed a small groove at the same place on both rear rotors, so I'm thinking that may be the origin of my sound. The pads feel healthy.
Old Dec 31, 2007 | 11:35 AM
DrWhoMini's Avatar
DrWhoMini
Ok, new development. I jacked the car up and the rear wheels do NOT spin freely with the E-brake DISENGAGED. I have to actually pull on the wheel for it to rotate.
What's that mean? Frozen e-brake?
theblackfalcon
Oct 11, 2015 09:49 AM
Tires, Wheels & Brakes
Aug 26, 2015 10:13 AM
Aug 25, 2015 09:18 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
