M7 Strut Tower Brace on R50?
has anyone tried fitting a M7 strut tower brace on a mini cooper? and does it not fit because of the battery box or is the hood to short? your responses would be great appreciated thanks.
M7 Strut tower brace
http://www.coopersport.com/usa/M7-St...e-p-16294.html
i got my awnser thanks anyways
Last edited by laggy; Dec 25, 2007 at 01:32 PM. Reason: i got my awnser thanks anyways
I intalled mine a while back and love it. I removed the under lining of the hood so I wouldn't get that flex I've heard about. After a couple of weeks, I noticed two little "nipples" on each side of my hood. I popped the hood and saw that the two "nipples" came from the outer bolts (two at each end to adjust). Peter from M7 told me that the their STB wasn't fabricated for the R50 due to the differences in it's hood. I've also been told that others have installed the STB with the hood liner still intact, and only have a little gap with the hood flexing (no nipples). Needless to say I love it and still have it on mine. A big plus with the R50 is that the brace fits snug over the battery cover and secures it well.
I got a set of those nipples on the hood as well!
you should have the eye of an eagle to see mine though !
the M7 strut tower brace does fit with a slight and easy battery cap surgery and I have to say it is amazing!
before installment I suggest you pay close attention to your strut towers!!!if bent DO NOT install or else the nipples on the hood will just be the first thing to worry about!
you should have the eye of an eagle to see mine though ! the M7 strut tower brace does fit with a slight and easy battery cap surgery and I have to say it is amazing!
Sorry, It's been a long while since I've been on this site. Regarding the "nipples" the M7 strut tower brace leaves is caused by the four bolt heads that secure the bar to the strut tower braces. I've replaced the four bolts with bolts with low profiled heads. I no longer have the "nipple" causing issue. Just thought I'd update this thread just in case somebody else comes along reads this thread.
molala
Oct 2, 2015 01:53 PM
M7Speed
Sep 4, 2015 10:47 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
