R50/53 DTC Codes...
Old Dec 21, 2007 | 08:50 AM
txwerks's Avatar
txwerks
DTC Codes...
If there are any techs out there, I'd appreciate some help on these two DTC's...
P0704 - Clutch switch circuit malfunction
P0571 - Cruise/Brake Switch Circ Malfunction
Symptoms - When trying to turn cruise control on, the indicator light flashes 3 times and then goes out. The cruise control does not work. The other symptom is that the brake lights work intermittently.
I replaced the brake light switch, checked all grounds, fuses, checked all bulbs in the rear for the brake light issue - still comes and goes.
Old Dec 21, 2007 | 09:57 AM
olngry's Avatar
olngry
Sounds to me that you should have replaced the clutch switch. Cruise kicks out when you depress clutch. If switch is defective it would keep Cruise Control from working. Good luck.
Old Dec 23, 2007 | 09:15 PM
chpsk8's Avatar
chpsk8
+1 for the clutch switch!
Old Dec 24, 2007 | 06:25 AM
jabell2r's Avatar
jabell2r
Coordinator :: M2C2
Try Starting the car (in neutral) without depressing the clutch. If it starts I think you would have your answer.
blantonator
Oct 2, 2009 04:43 PM
Blitzkrieg.
Jul 29, 2008 10:08 PM
fronesis47
Factory JCW Talk (2009+)
Jul 27, 2008 10:44 AM
gizzer777
Apr 14, 2007 02:04 AM
TonyB
Jan 12, 2007 07:45 PM
