Suspension Strut Tower Brace cause understeer?
Old Dec 20, 2007 | 04:48 PM
orbeamike's Avatar
orbeamike
Recently I installed a M7 STB to help protect mushrooming, also for any potential handling benefits.
My car is a 2005 Cooper S with Sport stock suspension. I did change my wheels to Pro Race 1 and non runflats.
My 1st driving impression is that the car understeers more. Is this likely? Or am I just imagining things?
Overall, I notice less rattling and driving over bumps seems to have muted.
your thoughts?
Mikee
Old Dec 20, 2007 | 04:51 PM
JustJAY's Avatar
JustJAY
I can't answer you because I had the STB and RSB installed at the same time. However, if you installed the wheels at the same time, perhaps a rotation/balance/alignment issue may be the result.
Old Dec 21, 2007 | 02:30 AM
succubus's Avatar
succubus
It is possible that with the different tires you have more grip. I know the front and rear were changed equally but it may affect the rear more than the front due to the lack of negative camber in front. Adding the FSB willd definately make you more solid up front, but the lack of rattling could be due solely to the softer sidewalls of the non runflats.
I put the M7 brace on before I added the RSB and don't recall feeling increased understeer, just a more solid and predictable feel to the whole operation.
Old Dec 21, 2007 | 06:05 AM
jonnieoh's Avatar
jonnieoh
Coincidentally, I have the exact same combination of items you do:
m7 STB
17" Team Dynamics Pro Race 1 wheels
Non-runflat Kuhmo tires
I did not notice any tendency to understeer more...
Old Dec 21, 2007 | 06:09 AM
minimusprime's Avatar
minimusprime
simple. remove the bar. drive around put it back on drive around. post results.
Old Dec 21, 2007 | 10:44 PM
minibeel's Avatar
minibeel
Coordinator :: PDX MINI
It's not just you, I noticed a tad more under-steer with the front strut tower bar. 19mm rear bar brought it closer to neutral.
dan
Old Dec 22, 2007 | 04:50 AM
Crashton's Avatar
Crashton
I didn't see that after I installed the M7 brace. The handling dynamics appeared to remain the same.
I installed an H-Sport 19mm rear bar & that made everything feel very nice.
Old Dec 31, 2007 | 05:40 PM
jefeant's Avatar
jefeant
I did it backwards from you. I first changed the rear sway bar to a hollowed 21mm and noticed significant oversteer. The week after I installed the M7 struts brace, and the entire car turned neutral all the way = a plessure to drive and the most predictable handling.
YaTuSabe
Aug 23, 2018 11:41 AM
OutMotoring
Mar 3, 2017 06:29 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
buggyeye401
Oct 1, 2015 01:22 PM
Suspension Products
Oct 1, 2015 11:53 AM
