R50/53 Power Steering failure??
Old Dec 13, 2007 | 03:53 PM
kraus_meister's Avatar
kraus_meister
Has anyone ever have their power steering system fail while driving?? I have an 2004 R50 and the fluid in the tank and yet I have no idea whats wrong. Any suggestions? Thanks
Old Dec 13, 2007 | 04:05 PM
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
Yes, it happens. One fellow club member had his go out in his 2005 MCC on the way home from the dragon this year. He was able to drive all the way home without any real problems.
Time to call the dealer or find a good shop.
Old Dec 13, 2007 | 04:27 PM
kalbone's Avatar
kalbone
mine failed while i was driving some where... im too lazy to fix it and plus i like having no power steering..
u might have a leak...or u might have something cloggin your power steering fan..
Old Dec 14, 2007 | 02:35 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
So it's ok to run long term with the powersteering disabled? Would pulling a fuse to see what it's like be ok to do? I have never had powersteering fail, but I've driven cars without it, it's fun. But they had steering systems 'geared' for no power assistance.
Old Dec 16, 2007 | 04:06 PM
kraus_meister
thanks for the advise guys!
Old Dec 16, 2007 | 07:27 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
I really wouldn't suggest driving with a failed P/S pump. With all the strange Engine fires I would be concerned. The main battery power to the pump isn't fused, and wouldn't want it to short. That can cause a fire.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Dec 16, 2007 | 08:53 PM
MiniMac2005's Avatar
MiniMac2005
sheepishly raises hand from the back of the room...
no PS.. that would be me lost it about 10 miles before Knoxville heading home to CHGO. At first, I thought I was just tired. Then, on a long, sweeping turn on the highway, I noticed the steering was really tight and it took a bit of effort to get the MINI to make that slight turn.
We pulled off to get gas and I knew I was in trouble because I had trouble trying to steer the car near the pump. After sitting for 10 minutes, the PS was fine. then, 10-15 minutes on the road, it was out again. I'd say I drove nearly 600 miles without PS. Luckily driving through Indiana is pretty straight. The MINI is not set-up to drive without PS.
I got it fixed the next day at the dealer under warranty.
Old Dec 27, 2007 | 01:33 PM
RON LAWRENCE's Avatar
RON LAWRENCE
power steering failure
My 03 cooper lost it's power steering while parked and then caught on fire.So far I am into it for a new pump, plug fan, wiring harness, fluids,pressure hose and a lot of labor.Has anyone else had a problem like this? Unfortunatly the car has 60k on it and is no longer in warranty.
Old Dec 27, 2007 | 01:57 PM
mcs22004's Avatar
mcs22004
An elegant solution would have been to leave power steering out altogether or at least make it optional. The electro-hydraulic steering is just one more thing to break, and it will break. My latest power steering motor is in the whining phase and will die soon. I have absolutely no problem turning the steering wheel, even at a stop, when the power steering is not working.
Old Dec 27, 2007 | 05:06 PM
es9194's Avatar
es9194
My 04 cooper's power steering failed right after I drove down the freeway. I have my car tolled to the dealer, and they said the power steering oil pump was broken. I got mine replaced for free. If you are still within the warranty, go fix it as soon as possible. If not, maybe it's the time to shop for an extended warranty. :D
Manny_cooper
Sep 10, 2015 11:09 AM
bansasn
15
Sep 4, 2015 01:24 PM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
minipopkart
Aug 13, 2015 05:22 AM
