Suspension Ireland Adjustable Camber Plate (street) Instructions?
Old Dec 6, 2007 | 09:31 PM
sprp85's Avatar
sprp85
I purchased a set of Ireland camber plates a while back and I might install these with H&R coilover this weekend. I do understand the basics but I just cannot tell which side is which (Left , Right) and in what way do I have to attach the top plate to the aluminum blocks. Urghh
here is a picture of the plates (borrowed from anotheR NAM member)
Can anyone determine which one is left and which ones right?
Thanks in advance.
Old Dec 6, 2007 | 10:23 PM
glnr13's Avatar
glnr13
just taking a guess here but i think the one on the left is for the driver's (US) side. goal is for negative camber so the strut would have to move in towards the engine bay
Old Dec 7, 2007 | 05:49 AM
sprp85's Avatar
sprp85
ah! I see thank you!!
Old Dec 7, 2007 | 11:00 AM
sprp85's Avatar
sprp85
Now, anyone know the way to attach the aluminum block?
they are not symmetrical so I believe one side must face towards the car and vise versa....
Also, which holes should I use for the plate bolts? 4 holes? skip 1 hole? etc?
Old Dec 7, 2007 | 04:00 PM
spdfreak's Avatar
spdfreak
I too am installing these plates this weekend, and from what I've been told by both Detroit Tuned and Texas Sperwerks is that when you go to attatch the plate the "guides" for adjustment should appear to be paralelle with the engine, if they appear to point toward the windshield they are backwards. And remeber two spacer underneth the bearing and one on the top to prevent binding.
Old Dec 7, 2007 | 04:36 PM
PGT's Avatar
PGT
Old Dec 7, 2007 | 07:41 PM
sprp85's Avatar
sprp85
Oooooo thank you all.
So I believe the picture i have linked is indeed in right formation hah!
Right plate is for passenger, Left plate is for driver (in the pic)
Can't wait til I put them on ooo
thank you all again!
Old Jul 16, 2008 | 05:58 AM
nickbmw's Avatar
nickbmw
I installed Koni sports with Ireland adjustable top mounts, the mechanic put 2 spacera under the bearing and one on top, is this right?
Also, i have a problem. Even though the alignent seemed good, i have a stronf pull to the right, and i have to hold the steering to the left to go str8.
Any ideas what may be wrong?
Old Jul 16, 2008 | 09:22 AM
Bang110's Avatar
Bang110
Get it Re aligned with you sitting in the car.
Old Jul 17, 2008 | 11:08 AM
AutoXCooper.com's Avatar
AutoXCooper.com
Something is not right, take it back to the shop that did the work and have it checked. One spacer on top and two on the bottom. Shouldn't pull at all. Then get a new 4 wheel alignment with you in the drivers seat.
Old Jul 17, 2008 | 11:33 AM
nickbmw's Avatar
nickbmw
Ok, so where do those six spacers go? There are three with each top mount. And also, my mechanic removed those thin metal sleeves from within the bearing, whith these on the Shock piston couldn't go through the bearing. Is this right or he messed up everything?
Old Jul 17, 2008 | 12:35 PM
AutoXCooper.com
What is the build date of your MINI?
NOTE from both our websites, "Note: These plates do not fit early chassis (before 04/2002) due to the upper strut bearing being different"
Old Jul 17, 2008 | 12:42 PM
nickbmw's Avatar
nickbmw
My MC is 01/2002 build date, but for my good luck it came from the factory with the anti roll bar end links attacked on the body of the shock, not on the spring seat. Even if it was the older version, with the end links attached on the spring seat, it has nothing to do since i use Konis for 04/2002 and after shocks.
About the alignent, it's not the driver weight the case. If it was this, when i put a codriver in last night, it shouldn't pull
Old Jul 17, 2008 | 12:59 PM
AutoXCooper.com
My MC is 01/2002 build date, but for my good luck it came from the factory with the anti roll bar end links attacked on the body of the shock, not on the sprint seat. Even if it was the older version, with the end links attached on the spring seat, it has nothing to do since i use Konis for 04/2002 and after shocks.
OK, if it was me, I'd take it all apart and look for the mistake, then put it back together. I have called two of my tech reps and based on the above info, we don't know what it could be, unless there was a mistake during install. The reason I encourage owners to be in the MINI for alignment is an issue of rear camber not front. Larger guys like me throw out the rear chamber when we sit in a MINI. Guess I should skip the DQ Drive thru.
Old Jul 17, 2008 | 01:04 PM
nickbmw's Avatar
nickbmw
I really apreciate your help, i think i'll do what you suggest soon. But could you please tell me where do those six spacers go? And why the sleeves had to be removed from inside the bearings?
Another guy posted above, and said he installed two spacers under the bearing and one on top too.
Old Jul 17, 2008 | 01:14 PM
nickbmw's Avatar
nickbmw
These are the spacers i am talking about, and where the sleeves are, which were removed.
Attached Thumbnails Ireland Adjustable Camber Plate (street) Instructions?-img_4837.jpg
Old Jul 17, 2008 | 03:24 PM
Bang110's Avatar
Bang110
why doesnt IE give directione with this? kinda seems hard to understand for the DIY installer.
Old Jul 17, 2008 | 03:32 PM
AutoXCooper.com
Because IE is a race shop, that happens to sell parts to others. They assume that you know what you are doing, or have a hired man doing the work.
I however do not assume that and will do whatever I can to help. NAM is a great place to find install help and tips. If I had the time and cash to make install sheets or videos for all the parts I have on line I would.
Old Jul 17, 2008 | 03:34 PM
AutoXCooper.com
Two spacers on the bottom and one on top. The sleeves being removed may reduce the life of the bearing, but it's unknown at this time.
Old Jul 18, 2008 | 09:50 AM
nickbmw's Avatar
nickbmw
And if someone wants to replace the bearings, do we know the price? Ireland mentions the the bearings are replaceable!
Old Jul 18, 2008 | 09:59 AM
jasonsmf's Avatar
jasonsmf
Look closely at the sleeves, there might be a burr that is preventing them from fitting over the strut shaft. I had this problem with mine, Ireland gladly sent me another set of sleeves for free that were just as bad as the first set. Once I removed the burrs, the sleeve would then fit over the strut shaft.
Jason
Old Jul 18, 2008 | 10:05 AM
jasonsmf's Avatar
jasonsmf
The bearing Ireland uses is a standard Aurora spherical bearing. Off hand I think it's a COM-12t, which is a 3/4" bearing with a teflon liner. A quick google led me to this
http://www.bsrproducts.com/product_i...96e15337a73a8d
Looks like $16.25 each. I have no experience with that company, that link is "for reference only".......Be sure to double check that part number also, the part number is stamped on the bearing itself, you can see it when the camber plate is disassembled.
Jason
Old Jul 19, 2008 | 03:04 AM
nickbmw's Avatar
nickbmw
Do you think i 'll have problem having the sleeves removed? Thanks a lot for the help!!
Old Jul 19, 2008 | 07:01 AM
jasonsmf's Avatar
jasonsmf
With the sleeves removed, you are going to have a lot of slop in there. I would think this would beat up the strut shaft pretty bad over time, not to mention clunk like mad.
Jason
Old Jul 19, 2008 | 09:23 AM
Bang110's Avatar
Bang110
Maybe those of you who have installed the IE plates could do a write up on the proper install. I know it would help alot of people.
