Pirelli P-Zero
Old Dec 5, 2007 | 11:00 PM
2packt's Avatar
2packt
Pirelli P-Zero
are these good tires??? better than the standard run-flats???
Old Dec 5, 2007 | 11:19 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Yes
and
Yes.
The smallest size they come in is 225/40-18 which is 25.1" tire diameter compared to 24.4" for a stock MINI tire and too large to fit without rubbing.
Essentially it was first on a recent test
http://www.tirerack.com/tires/tests/...ireModel=PZero
Whenever you want to check on tires, look them up and check the sizes. No matter how good the tire, it is doesn't come in sizes that are MINI friendly then it doesn't matter much.
That's why you always tend to see the same tires mentioned over and over.
If you have questions try calling Alex@tirerack.com
Old Dec 6, 2007 | 09:29 AM
2packt's Avatar
2packt
Originally Posted by minihune
Yes
and
Yes.
but they do have 215/45 17....p zero nero...datz what im talkinb bout...
Old Dec 6, 2007 | 10:35 AM
succubus's Avatar
succubus
They also come in 215/35-18
http://www.tirerack.com/tires/Compar...=All&x=96&y=14
Old Dec 6, 2007 | 10:55 AM
minimusprime's Avatar
minimusprime
pzero and pzero nero are different tires.
Old Dec 6, 2007 | 12:57 PM
minihune's Avatar
minihune
Correct. Lets make sure we are talking about the same tire.
http://www.tirerack.com/tires/pirelli/pirelli.jsp
In Max Performance Summer tires:
Pirelli PZero
No sizes smaller than 225/40-18 $243 each!
and
Pirelli PZero Nero
Yes 215/35-18
Yes 215/45-17 $138 each 220 treadwear
Test results below- (see also customer reviews)
http://www.tirerack.com/tires/tests/...ay.jsp?ttid=43
Old Dec 14, 2008 | 07:08 AM
uzun's Avatar
uzun
I may be interested in the runflat version of these tires. TireRack shows that Pirelli P-Zero now has a runflat version in the 205/40-18 size. I am planning on getting some lightweight 18" wheels soon and I am looking for a set of 18" runflat tires that have the best possible performance. I may even take these new 18" wheels/tires to the track few times a year.
The non-runflat version of Pirelli P-Zero has excellent reviews on TireRack: http://www.tirerack.com/tires/tires....ireModel=PZero
But there are no reviews on the runflat version yet. Can I assume the main difference between the non-runflat and the runflat version will be stiffer sidewalls? In other words, is it safe to assume the performance and handling of the runflat version is about the same as that of the non-runflat version? I am in the minority who likes runflats and I don't mind giving up a bit of ride quality as long as the tires will perform great otherwise.
Old Dec 14, 2008 | 08:44 AM
bolar's Avatar
bolar
I have the 16" zero nero and for an all season, you can find better. In snow they are horrible. They are not even as good as the original runflats I had.
I have since bought some winter tires for this time of year. When the zero nero's wear, I'll be looking for something different.
Old Dec 14, 2008 | 08:53 AM
Herman da German's Avatar
Herman da German
I'll second that I had a set of those except 19's on my Audi TT. They suck! I bought Goodyear's for the Cooper. They are quite a bit better on the ice not to sure about snow. I really can't take it out in snow because it sits so low.
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
AoxoMoxoA
Sep 30, 2015 06:00 AM
Brian_in_VT
Sep 18, 2015 05:57 PM
hexproject
Sep 7, 2015 08:23 PM
Kat Maerz
Sep 1, 2015 04:30 PM
