R50/53 Do I need a belt for a 17% pulley?
Old Dec 5, 2007 | 08:16 AM
Weedo's Avatar
Weedo
I know, rookie question. I've heard both "yes" and "no". If I do indeed need one, can someone link me to a good place to buy one?
Old Dec 5, 2007 | 09:06 AM
tennis_man's Avatar
tennis_man
You can pick up a good belt at your local Napa Auto Parts store. The part number for the belt that works well with a 17% pulley is #060539.
Here is a chart from Alta Mini Performance web site:
Old Dec 5, 2007 | 09:13 AM
agranger's Avatar
agranger
You might be able to get away with the stock belt on a 15% pulley, but odds are that it's gonna slip in a few thousand miles. You might not feel it, but you aren't getting all the power out of the engine (and if you didn't want it, why do the pulley in the first place? :D )
You will definatley need a new belt with a 17% pulley. It's not a bad idea to replace the old one anyway... I change mine every 15,000 miles as a cheap, preventative measure with a 16%.
Old Dec 5, 2007 | 09:15 AM
Weedo's Avatar
Weedo
Very good info! And thanks for the quick response!
Old Dec 5, 2007 | 10:19 AM
minimusprime's Avatar
minimusprime
i don't agree with that chart... i run a 060535 on my 15% only car.
Old Dec 5, 2007 | 10:53 AM
Weedo's Avatar
Weedo
Uht-oh, I just picked up the belt based on that chart...
Old Dec 5, 2007 | 10:57 AM
Yucca Patrol's Avatar
Yucca Patrol
You'll be fine with the belt suggested by Alta. It is a pretty slim chance that Alta got their part numbers wrong, and the belt tensioner makes up for any slight variance in the belt size.
My personal opinion is that one should almost always get a new belt anytime you have a reason to get in there and change it. I'd always rather buy a part than do the work twice.
Old Dec 5, 2007 | 11:29 AM
minimusprime
Don't worry about it. Previously I ran a 060539 for about 8k miles without too much problem at all. It was definitely slipping at about the 6k mark however.
Old Dec 5, 2007 | 11:46 AM
Weedo's Avatar
Weedo
Ok, sounds like I should be ok then. I probably won't put more than 6,000 miles on the car in the next 2 years so I should be safe for a while!
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
daviday
Sep 25, 2015 01:31 AM
makg
Sep 24, 2015 11:10 AM
Emnotek
Sep 11, 2015 04:16 PM
