R50/53 2004 MCS rim bolt pattern
Old Nov 28, 2007 | 08:12 PM
RatBlast's Avatar
RatBlast
i am in need of some snow tires and want to get 2 steel rims in a 13 to 15 inch size with some high profile snow tires. i see the do not make a snow tire for my 17 inch rims.
can some one tell me what rim would fit onto my cooper s ? i want to buy some from a wrecker .
Old Nov 28, 2007 | 09:33 PM
TheWrks's Avatar
TheWrks
Coordinator :: Michigan MINI Motor Club
The bolt pattern is 4x100
I would not go smaller than 15 as smaller one probably will not clear the brakes.
You can get Winter tires for your 17's
http://www.tirerack.com/snow/WinterP...4&autoModClar=
Old Nov 28, 2007 | 09:42 PM
COR BLMY's Avatar
COR BLMY
My son tried on a 13" at our last auto-x
The rim hits the lower ball joit and will not even line up with the wheel bolt holes.
Unless you had some AMAZING negative offset.
Maybe a 14 ???
but tire choices are limited on 14s
Old Nov 29, 2007 | 05:37 AM
RatBlast's Avatar
RatBlast
thanx for the info guys will go check the wrecker this weekend to find some 15 inch honda rims . will find out what is cheaper , rims or some bridgestone snow tires.
Old Nov 29, 2007 | 05:49 AM
JAB 67's Avatar
JAB 67
Are you considering putting these only on the front? Bad idea.
Old Nov 29, 2007 | 05:51 AM
Yucca Patrol's Avatar
Yucca Patrol
Most definitely. It is probably much safer to have 4 regular tires than 2 snow tires on the front.
You don't want your front tires writing checks your rear ones can't cash.
Old Nov 29, 2007 | 05:55 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
15x5.5
4x100 bolt pattern
56.1mm centerbore
ET45 offset
Old Nov 29, 2007 | 06:18 AM
markertoo's Avatar
markertoo
Whoa, whoa, whoa! There is more to buying wheels or tires than getting a pair for the front.
First off, winter tires ARE made for your 17" wheels, but they are expensive. IF you did that, but 4. Period. If a customer were to come in to our store and say that he was only buying 2 winter tires, I would send him down the road. I do not want the liability, and only 2 winter tires will NOT work properly. Differences in construction, sizes, sidewalls, speed ratings, and many other things will conspire to make a 2 tire deal very bad for your car.
Not a lot of 15" steel wheels will fit our cars, but most 15" alloys will. The bore size of the wheel is also important. Honda's actually use a 56.1mm bore, so they would fit our cars. But, they use a ball seat nut or bolt. If you plan on using Honda wheels, either convert to studs, with the Honda nuts, or use some of the 12mm VW wheel bolts.
If you are trying to stay on a budget, see if someone has a used set of winter wheels or wheels and tires.
Old Nov 29, 2007 | 06:11 PM
RatBlast's Avatar
RatBlast
well it looks like i have no cheap way out lol
i will go and look into getting 4 snow tires i guess. i really did not have plans on driving my mini more than one winter , but i do not have the extra cash at the moment to buy a winter beater. the mini is just to low for any real snow falls , mine will be lowered in the spring next year .
Old Nov 30, 2007 | 03:33 PM
vdubdoug's Avatar
vdubdoug
i have driven my lowered 2002 mini in some northeast (long island snow). I had blizzaks on the car and it did fine . I had the car for 1 year and 4 months (2 winters) and racked up 40k miles and never once did snow stop me.
There are plenty of good deals in the Wheels and tires for sale forum: Also check other local Mini forums for good deals. I found a set of one season old Bridgestone blizzaks on 16" steel rims for 275.00 If they last me 2 winters (since i won't be driving much this winter) I think I scored a great deal.
Old Dec 2, 2007 | 09:19 AM
Eds not-so-red MINI's Avatar
Eds not-so-red MINI
I have a set of 15" snow/ice tires that were incredible on my PT Cruiser in all kinds of nastiness. I'd like to keep them for my soon-to-be-arriving MCS if it's at all possible. Is there a 15" wheel that will fit an '07 MCS, or is that idea nixed because of those marvelously oversized brakes? I tried Tire Rack, but the smallest they have is 16" and way too nice for snow & salt & that NE-wintry crap.
Thanks much ...
ed
Edit -- Bavarian autosport (http://www.bavauto.com) has 'em, but they cannot confirm if they'll fit an '07.
Spank
11
Apr 9, 2020 02:23 PM
SosoMINI
Nov 22, 2015 03:17 PM
TOMSR53
Aug 26, 2015 10:18 AM
col127
Aug 21, 2015 02:11 PM
keck.j
Aug 18, 2015 08:18 PM
