R56 Question About 1st Oil Change
Old Nov 27, 2007 | 10:37 PM
byhsu's Avatar
byhsu
I currently have about 900 miles and i heard that after 1200 miles the motor is broken in. I would like to change the oil at 1200 miles. What oil besides Castrol Synthetic can I use? and what grade? Also should I change the oil filter too?
Old Nov 27, 2007 | 10:52 PM
scott48's Avatar
scott48
I would still use 5w-30 and probably use the Castrol that MINI recommends, but Mobil 1 is good as well....always change the filter when you change the oil.
Old Nov 27, 2007 | 11:44 PM
Robin Casady's Avatar
Robin Casady
There are several synthetic oils you can use, but you have to be sure to get 15,000 mile rated full synthetic if you want to stay with MINI specs. The MINI branded Castrol the MINI dealer sells is reasonably priced, and you know it is to spec.
If you go with Mobil 1, make sure it is Mobil 1 Extended, not regular Mobil 1. The regular stuff doesn't meet spec.
There have been several threads debating the various oils. Search this forum and you will find lots to read.
Oh, and it is probably more important to change filters than to change oil.
Old Nov 28, 2007 | 12:50 AM
Oakland Raiders Mini's Avatar
7,500 miles with the original oil on mines. No problems so I'm not changing anything.
Old Nov 28, 2007 | 08:27 AM
byhsu's Avatar
byhsu
Any type of specific oil filter that I should look for?
For the oil the specs have to be 15,000 miles and 5w-30?
Old Nov 28, 2007 | 09:01 AM
Robin Casady
I used the OEM filter. It is available from several vendors listed here on NAM. Check around for the best price. You might find that mentioned in one of the other threads. I bought this:
http://new.minimania.com/web/Item/G2.../InvDetail.cfm
However, the 27mm socket is easy to find at any auto supply, and you need a Torx for the drain plug. There is a good DIY oil change thread with instructions and photos. It has the specific OEM specs for the oil as well. Basically, it is 5w-30 full synthetic rated for 15,000 miles. However, there are some SAE numbers that might make it easier to sort out in store.
Old Nov 28, 2007 | 09:03 AM
mattminicoop's Avatar
mattminicoop
I must admit this whole do change the oil, don't change the oil is baffling. I got mine in June and have about 6800 miles clocked up already.
Those of you that do decide to get oil changes, I presume you don't get the counter reset, so you can still take advantage of your 'free' oil change from Mini?
Also, does anyone know a trusted place to get the oil change done in the Pittsubrgh area?
Old Nov 28, 2007 | 09:19 AM
r56mini's Avatar
r56mini
If you order 4 here, total comes to $52.xx....with shipping. Does anyone know any other place with better price?
http://www.minicarparts.net/Parts/11_42_7_557_012.cfm
Old Nov 28, 2007 | 09:30 AM
Robin Casady
OK, I'll look up the DIY thread for you.
https://www.northamericanmotoring.co...d.php?t=101513
No, your OBC does not get reset. For most of us it is going to at the one year interval, anyway.
Your dealer, but it will be expensive.
I wouldn't go to any of those quick oil change services. I had a very bad experience with Jiffy Lube, and another one I tried (previous car) over-filled some fluids.
It is actually fairly easy to do it yourself if you use one of those containers that catch and hold the oil. Just buy the right tools and do it yourself.
Old Nov 28, 2007 | 09:45 AM
Yucca Patrol's Avatar
Yucca Patrol
Just look for the gold colored cap and you'll know you have the right stuff.
Old Nov 28, 2007 | 09:47 AM
byhsu's Avatar
byhsu
I got a friend who will help me do the oil change, He is got one of those pumps that sucks the engine oil out, without having to get under the car.
All I need is to buy the right oil and oil filter. For Oil I am going to Costco to get their Mobil 1 synthetic 15K mile oil. Any links for the oil filter, or what store carries it?
Old Nov 28, 2007 | 10:28 AM
johne123's Avatar
johne123
actually
By the time you notice anything about the health of your motor it will be far too late. Oil that's too old with cause accelerated wear on a micron level. I'm not saying 7500 miles is too long. Just keep in mind the only way to know if your oil is still doing it's job is to have the oil analyzed.
Since there have been reports of fuel dilution with direct injection engines, including one confirmation on a R56, I'm having my oil analyzed at 5000 miles to see how it's doing.
Old Nov 28, 2007 | 10:46 AM
byhsu's Avatar
byhsu
After you have the oil analyzed, could you let us all know your findings?
Thank You
minibayb's Avatar
minibayb
I just bought OEM oil filters from minicarparts.com a vendor here on the board but I think there are others that sell here also. $10.95 per filter which seemed reasonable for OEM filter. While my mini is under warranty I wanted to only use OEM filters and spec oil. I have always done my own oil changes but I also keep my receipts for filters and fluids along with detailed records to substantiate maintenance done to prevent future warranty issues.
Old Nov 28, 2007 | 10:58 AM
Yucca Patrol
Might just be easiest/best to get a filter from a MINI dealer.
I've found that the big jug of oil is cheaper at Wal-Mart than Costco
Old Nov 28, 2007 | 11:01 AM
byhsu's Avatar
byhsu
For the Mobil 1 Synthetic 15,000 miles oil? How many quarts do I need?
Old Nov 28, 2007 | 02:00 PM
spfdhed's Avatar
spfdhed
FWIW I just turned over 1200 miles and changed my oil. I got a OEM filter kit from MiniMotoring. I went to the local autoparts to pick up oil and after carefully scrutinizing the service designations on mobile 1 extended service and castrol full synthetic went with the latter. It was listed as exceeding SJ (which is what the owner's manual recommendations are) whereas the mobile didn't list SJ service. I also discussed it with the parts guy (who asked specifically what car it was for and then recommended the castrol over the mobil).
Old Nov 28, 2007 | 02:42 PM
byhsu's Avatar
byhsu
what is SJ? Where do they sell Castrol full synthetic for cheap. I saw it at autozone at about $6/quart
Old Nov 28, 2007 | 02:51 PM
Robin Casady
IIRC, it was $5.40 at my MINI dealer (MINI of Mountian View)
Old Nov 28, 2007 | 03:58 PM
SteelersFan's Avatar
SteelersFan
I just picked up the MINI branded oil for $5.40/qt also at Nick Alexander MINI of Los Angeles. They sold me the filter for $18.00 which is more than the on-line places sell for but was convenient to get the oil and filter in one place.
Old Nov 28, 2007 | 04:07 PM
twin scroll's Avatar
twin scroll
Walmart has 5 quart jugs of both Castrol full synthetic and Mobil 1 and is the cheapest around here.
Old Nov 28, 2007 | 04:48 PM
r56mini's Avatar
r56mini
At Walmart, 5qt Castrol is $19.97.
Old Nov 28, 2007 | 05:14 PM
SteelersFan
I erred on the side of caution by purchasing from MINI since I will only be changing my own oil this first time. When the free maintenance runs out I will go back to changing it myself and will be looking at getting supplies less expensively.
Old Nov 28, 2007 | 09:46 PM
ekailee's Avatar
ekailee
I have spent hours, literally, researching oil or no oil change. My conclusion-its my car and my piece of mind. I changed my oil at 1200. You don't "need" to change the oil until 15000 miles per MINI but for the $50 you will spend initally (low pro ramp, 27mm socket, oil, filter) I have piece of mind. NOw if you are going to change your oil I would always change the filter. I used one from MINI. As to what oil to use Mobil 1 or Castro Syn, i think it is like the question Chevron or Mobil gas. OK now I will hear all the reasons why chevron v mobil.
Old Nov 28, 2007 | 11:47 PM
I didn't change it because I don't know how. Not because I'm cheap. I saw on TV that places that were supposed to change your oil didn't even perform the service. If anyone is by Monterey Park, CA and can help I'd be grateful =)
