wheel stud kit
Old Nov 21, 2007 | 04:46 PM
ScottinBend's Avatar
ScottinBend
wheel stud kit
So what is the consensus on the best stud kit?
Old Nov 21, 2007 | 06:16 PM
tazio's Avatar
tazio
TMS
Old Nov 21, 2007 | 07:59 PM
gnatster's Avatar
gnatster
I've been using the ones from Texas Speedwerks with no issues. But really and decent set will all work the same.
Old Nov 21, 2007 | 08:07 PM
PGT's Avatar
PGT
I disagree about all the same. I got a set from Pilo Racing....it's poop (threads didn't hold it very well). Dan got me a hardened 'race' quality set for a few bucks more...they've held up great.
Old Nov 21, 2007 | 08:13 PM
ScottRiqui's Avatar
ScottRiqui
The black oxide coating on my TSW studs developed rust blooms on the surface almost immediately, but I've had no problems with the fit or function. The threads are holding up well, and you can tell they're well-made parts from how smoothly the nuts thread onto the studs.
I wasn't too disappointed about the finish, because I knew from the start that these pieces were more functional than cosmetic. I periodically wire-brush and oil the *exposed* threads after tightening the nuts, and that's kept them looking good.
Last edited by ScottRiqui; Nov 21, 2007 at 08:38 PM. Reason: They're black-oxide, NOT black-anodized.
Old Nov 21, 2007 | 08:19 PM
PGT's Avatar
PGT
uhh....that's black oxide, not an anodized finish. black oxide doesn't last. anodizing is for aluminum only and I'd be worried if the TSW stud kit was anything but steel
Old Nov 21, 2007 | 08:37 PM
ScottRiqui's Avatar
ScottRiqui
Sorry - brain fart - I've got anodizing on the brain after reading a different thread. Yes, the TSW threads are black-oxide coated. I'll change my post.
Thanks!
Old Nov 21, 2007 | 08:47 PM
tazio's Avatar
tazio
The TSW studs look ok but are not long enough for 15mm spacers, which is what you want to run up front...
Old Nov 21, 2007 | 09:24 PM
gnatster's Avatar
gnatster
The OP said nothing about using spacers. I know they do work with a 5mm. Not sure why you want a 15mm spacer.
As far as the bloom on the TSW studs go I don't get it. Since I'm changing wheels quite often I put a very small amount of anti-seize on the studs. the application from May of this year is still holding up fine with driving in all kinds of weather and multiple track days.
Old Nov 21, 2007 | 11:01 PM
70spop's Avatar
70spop
+1 for the Turner Motorsports, and one or two of our club members also got them after seeing mine. The 75mm ones should be fine with up to 15mm spacers, too, if that's of any consideration.
The Texas Speedwerks studs weren't out when I got the Turners (TSW actually directed me to TMS), but I'd just as easily recommend theirs.
Old Nov 22, 2007 | 01:38 PM
ScottinBend
Ok.....went to both sites and I have a question.
Is the price at TMS for the studs per stud or wheel?
Has anyone had any experience with the black nuts at TMS?
Old Nov 23, 2007 | 09:11 PM
drmike@txwerks.com's Avatar
drmike@txwerks.com
I've got TMS studs on the front of my car - I got them before the TSW studs were out also! Excellent product.
I believe the price of $6.96 each is per stud.
No experience with the TMS lug nuts.
Old Nov 23, 2007 | 09:22 PM
ScottinBend
$7 a stud............!
Damn.............so what's the difference between your studs and TMS's...?
I assume I need the M12 studs.
Do you have a suggestion for some black nuts?
Old Nov 23, 2007 | 10:21 PM
tazio's Avatar
tazio
I wasn't either until I tried them.
Old Nov 23, 2007 | 10:23 PM
tazio's Avatar
tazio
I have them. They have held the wheels on so far.
Old Nov 23, 2007 | 10:57 PM
ScottinBend
so it looks like I'll go with the TXW studs and the nuts from TMS.........
Old Nov 24, 2007 | 12:42 AM
tazio's Avatar
tazio
My work here is done.
Old Nov 24, 2007 | 05:38 AM
Crashton's Avatar
Crashton
Ok, could you enlighten me on what those spacers have done for you?
Old Nov 24, 2007 | 08:32 AM
MOTORN's Avatar
MOTORN
That ain't going to happen.
+1 For TSW 14mm studs and nuts. They work with 10 mm spacers or less.(depending on wheel thickness)
I have to use spacers to get a BB kit to fit with stock GP wheels. No spacers for track wheels.
Sorry Chuck, couldn't resist.
Old Nov 24, 2007 | 08:37 AM
Crashton's Avatar
Crashton
Ouch !!!!
That's gonna leave a mark.
Next time I see ya Rick I'm tagging your GP with Old Fart stickers.
MINI VINI
Oct 13, 2015 08:57 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
