Navigation & Audio Factory radio re-install help
Old Nov 19, 2007 | 02:21 PM
kyriian's Avatar
kyriian
I want to try to re-install my factory radio and i want to ask if there's anywhere might i find a how-to? i gotta take my alpine off first and find out if they hardwired the wiring into the new radio
otherwise, if anyone has a good how to please do let me know
Old Nov 19, 2007 | 02:39 PM
Eric_Rowland's Avatar
Eric_Rowland
I would think the best solution would be to get a chopped wiring harness from wrecking yard, then you need only match up the colors and resplice, assuming they cut the original harness. You'll need the OEM plug anyway.
Old Nov 19, 2007 | 03:15 PM
kyriian's Avatar
kyriian
i have the radio out, the harness was retained so i guess i am lucky
problem is though the red wire, from the graph of the alpine unit it says its to the ignition, that is directly plugged to the wire on the alpine unit
anyone know what's the red wire?, and if i re-splice everything, where does it go
Old Nov 20, 2007 | 03:52 PM
MINIMM's Avatar
MINIMM
All Harnesses have the Industry standard E.I.A color code
Professional Wire Harness for Installation of radios and stereos - Quick and Easy
Red is for the ignition, it becomes powered when you turn on your car
Got this off the internet, hopefully it applies to Mini's but not sure.
Old Nov 20, 2007 | 04:57 PM
kyriian's Avatar
kyriian
i plugged the radio back in the car, everything seems to work fine, radio recives, power to the unit, cd plays, just that red wire's function eludes me
i just stuffed it in the dash and put some electrical tape on it, lets hope it doesn't become a problem later
thanks
molala
Oct 2, 2015 01:53 PM
Sep 4, 2015 01:31 PM
Sep 4, 2015 11:43 AM
zr0z
Sep 3, 2015 04:50 PM
