R56 programming
Old Nov 6, 2007 | 10:39 PM
ghosthound's Avatar
ghosthound
programming
ok, so i picked up my MINI on monday and so far its awesome!! but im trying to figure some of the programming stuff... it seems like some of the stuff in the manual is not possible.
Ok, here we go....
First off, the manual isnt very clear about the rain sensor programming deal... when i scroll through the OBC, i see a picture with 2 different "clouds" i guess and you can select between the two, im assuming its sensitivity? but im not sure, can anyone with the auto rainwipers helo me here?
Next, pathway lighting... i have the auto headlights as well and it says the manual you can have it set so that the cars lights remain on after you lock it but my lights never stay on, i have it set to 40s but still nothing.
Next, the manual says you can have a audible alert when locking or unlocking the doors, all i get is the parking light flash... the OBC doesnt even display a sound icon.
finally, i have comfort access and i was wondering if there is any way to make it so that the interior lights come on when i get in range?
Thanks a lot everybody!
Old Nov 6, 2007 | 11:37 PM
Sowellman's Avatar
Sowellman
That sounds new. My car was an early March build and it didn't have any clouds or sensitivity settings. It was supposed to have a sensitivity setting for the auto on headlights, but didn't, either.
I haven't figured that one out, either. Like you, mine is set at 40 seconds, but it doesn't do anything.
That was a change for the U.S. market. None of the R56s come with an audible altert, despite what the manual says. I actually like that they're only allowing the light flash. Wish other manufacturers would do the same.
I haven't heard of any way to do that.
My car has been in the shop for the past week, after a software update didn't hold, after they installd the Ipod connector and the Sirius radio. They solved that problem and I am driving up to Portland on Thursday to pick it up. I'll let you know if any of those items above change from the general car software update.
Old Nov 6, 2007 | 11:42 PM
ScottRiqui's Avatar
ScottRiqui
Here's the owner's manual entry for the Pathway lighting:
The trick is that you have to pull on the headlamp stalk after turning the lights off (or after turning the car off, if you've got auto-on headlights). That will turn them back on for however long you've programmed the delay.
Old Nov 7, 2007 | 12:00 AM
nicknbecka's Avatar
nicknbecka
With mine, along with the two clouds, there's a small bar graph of four boxes along the bottom. With each press of the button OBC button, the next box fills in.
I wouldn't imagine so, my guess is that the keyfob is an RFID chip- the car sends an encoded radio pulse when you press the black button on the handle. (If you hold it down when a keyfob is out of range, you can here the car click.) In order to do what you're thinking, the car would need to be sending out pulses constantly, which would eventually become a battery drain issue.
nicknbecka's Avatar
nicknbecka
Also, the range of the comfort access portion of the fob seems to be about three feet
Old Nov 7, 2007 | 11:44 PM
ghosthound's Avatar
ghosthound
hmm, ive tried this but still nothing.... where did you get that online owners manual? id love to be able to read up on the comp instead of pulling out the manual out of the car...
thanks again everybody. now if someone could just tell me how to make the break in miles go by faster
Old Nov 8, 2007 | 05:13 AM
Minidrivr's Avatar
Minidrivr
That setting adjusts how much water it takes on the windscreen before the wipers work (in auto-mode only). Look at the end of your wiper stalk, you'll see a button, next to it there is a small window picture with an "A". You have to turn on the auto-wipers every time you restart the car by pressing this button. Once they are in auto mode, they will detect water and work depending on the setting in the OBC you are seeing.
See this thread for more info.
https://www.northamericanmotoring.co...d.php?t=115225
Old Nov 8, 2007 | 05:39 AM
rockridge's Avatar
rockridge
Seems about right. I am seeing the same. Occasionally have a problem when opening the back trunk.
Old Nov 8, 2007 | 07:28 AM
TurboBlu's Avatar
TurboBlu
The Audible Alert can only be used or de-activated if you have the factory or accesory installed Alarm system.
When you get that installed and programmed at your Dealer then the next time you go into the Computer to change the Parking light flash on lock/unlock function, there will be a audible alert+flash, Alert only, Flash only, or nothing option for both unlock and lock.
the pathway lighting should also work wether you have auto on lights or not.
Make sure it is set for like 40 s then start your car at night, then shut off the car, pull key out pull headlight stalk toward you once like you are flashing your lights, it should come on. If not, make sure your headlight switch is set to off not parking lights on headlights on. Then see if it works, that might have something to do with it.
Scott
Old Nov 8, 2007 | 07:42 AM
carjoy's Avatar
carjoy
Scott
Is this another one of those automatic - but really manual - options on the 07s. I have the rain sensor windshield that only works if you turn it on EVERY time you start up the car. I would expect the pathway lights to automatically stay on for 40s after I turn off the engine because that is how it is billed. If I have to pull this or push that then shut off the car and say a prayer before opening the door every time, I think I'll just get a flashlight!
Sorry.... feeling a bit like ranting today....
Old Nov 8, 2007 | 07:59 AM
TurboBlu's Avatar
TurboBlu
I understand, but sometimes you don't need pathway lighting so the give you an option i guess.
The Rain sensing wipers has to be activated everythime cause it would suck to go througha cash was and you mess up your wipers ina car wash or somethihng, i know bad example but it has to be that way, same as BMW's actually
Old Nov 8, 2007 | 08:26 AM
rkw's Avatar
rkw
That may rush you to get out of the car once you turn off the engine. It makes more sense that you turn it on just before you get out. Also, if it were automatic it would turn on even in the daytime.
Old Nov 8, 2007 | 08:53 AM
carjoy's Avatar
carjoy
Would that be so terrible? It is only 40s after all. What about daytime headlights? Same principle
Old Nov 8, 2007 | 09:29 AM
rkw's Avatar
rkw
No, it wouldn't be so terrible but at least to me it is intuitive for this to be a manual rather than automatic feature. By the way, the owner's manual says it can be set from 10 seconds to 4 minutes.
Old Nov 8, 2007 | 09:05 PM
ghosthound's Avatar
ghosthound
ok, just checked and the parking lights do work with a flick of the highs.
Old Nov 10, 2007 | 01:50 PM
ScottRiqui's Avatar
ScottRiqui
You can download owner's manuals from the "Owner's Lounge" portion of the MINIUSA site. I can't get into the OL right now, but I don't know if the issue is with their site or my browser.
If you send me a PM, I'll e-mail you a PDF version of the owner's manual.
Old Nov 10, 2007 | 04:12 PM
ghosthound's Avatar
ghosthound
ooo, well if its online then its no problem, i'll just dl it later. Thanks though!
Old Nov 10, 2007 | 04:19 PM
ScottRiqui's Avatar
ScottRiqui
I finally got through a little later. After you go to the Owner's Lounge, click on the "Your MINI" tab, and then select "Owner's Manual".
Or, you can get any of the MINI owner's manuals from my iDisk here:
Filmy
Jun 28, 2016 08:58 AM
bahman
Feb 14, 2016 10:29 AM
tcjake
Sep 30, 2015 08:14 AM
genik
Cooper (non S)
Sep 25, 2015 02:46 PM
kevins
Sep 23, 2015 12:12 PM
