Lugs get rounded after changing tires a few times?
Old Nov 1, 2007 | 01:21 AM
fjork_duf's Avatar
fjork_duf
I was wondering if it is good to periodically get new lug nuts. I have 17mm sockets for the lugs. I noticed a *little* bit of play and the nuts themselves look like the edges are rounded just a little bit. I'm not sure if I did that or if the tire place that rotated my tires did it. (before I got the tools and the extra set of wheels.)
What are your thoughts? With occasional tire changing should I consider getting new lugs? or a second set? If so where is a good online store to buy some?
Old Nov 1, 2007 | 05:02 AM
rhawth99's Avatar
rhawth99
That shouldn't happen if the correct 6 pt socket was always used. Sounds like somebody used the wrong socket on them once.
Old Nov 1, 2007 | 05:19 AM
Speedwing's Avatar
Speedwing
I agree with rhawth99 ..... It should not happen with 6 pt sockets. They grip on the flat sides.
Old Nov 1, 2007 | 05:39 AM
kenchan's Avatar
kenchan
i know cheezo tire places Discount Tire(America's Tires) use standard sockets on metric nuts/bolts.
had to replace all of my lugs long time ago cause the **** used an
impact on them. stopped taking my car to tire places ever since.
actually, i stopped shopping at DiscountTire (America's Tire) all to gether.
Old Nov 1, 2007 | 11:32 AM
Mineon's Avatar
Mineon
I've changed my wheels dozens of times with autocrossing and swapping back and forth from winter to summer tires. My stock lug bolts are still in great shape. I use a breaker bar to break them loose them, a cordless impact to remove and install them, and a torque wrench for final torque. No issues with rounding off the bolts at all.
Old Nov 1, 2007 | 02:00 PM
Crashton's Avatar
Crashton
Bingo ^^^
Old Nov 1, 2007 | 03:27 PM
fjork_duf's Avatar
fjork_duf
AHHHH That's it. That's where I had my tires mounted... LAME!!! But as long as I continue using 17mm I should be fine then?
Also where is a good web site to order some new lug nuts?
Old Nov 1, 2007 | 03:29 PM
fjork_duf's Avatar
fjork_duf
I use the same exact process with a 17mm socket
Colt45Magnus
Sep 7, 2015 10:47 PM
sprp85
Aug 22, 2015 06:16 AM
Mini'mon
Aug 16, 2015 04:15 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
